Tuya Smart Siren Zigbee - Driver doesn't work
Thank you @kkossev
I also have the "cheap" version as referenced by @putudhony88 , it does not have temp & humidity sensing, if that helps.
Thank you @kuzenkohome
Tuya Smart Zigbee Sensor Built-in Siren Alarm (without temperature and humidity sensors) driver is now available here:
Thank you @putudhony88 and @kuzenkohome for the tests!
For anyone considering purchasing these sirens, note that there are 2 versions that look identical.
The one referenced here is the "cheaper" version (usually <$20USD) it DOES NOT have a temperature or humidity sensor that is present in the more expensive versions. They are USB powered with battery backup. The vendors play fast and loose with their descriptions so read carefully if you want the temp & humidity feature.
It functions as a ZigBee router. I haven't tested it for long term stability as a router though .
This is what they look like.
Gents,
I have the tuya TS0216 siren and the siren goes off every time i get an error message as listed below.
for the driver I am using
when I change the driver, i set it to device then initialize then back to the new driver then configure.
I have tried the following driver but it did work.
any suggestions?
thank you.
Have you tried Marcus's Siren driver? It is on HPM
hi kkossev
Glad to hear back from you.
in the matter of fact I tried the following drivers
only the generic zigbee siren worked but as I have mentioned it goes off for 2 seconds every time I get an error from it
mainly almost on the same time. that is my analysis.
I am only using it in ham as my siren.
I have removed the siren to see if it goes off by itself. I do not thing it is the siren.
hi kkossev
sorry I did not answer your question
I searched through hpm the only siren may be for Marcus - ohlalabs is the Las one but it did not work.
am I correct?
Yes, I meant that one Marcus's driver, but looking at the code it is not the right driver for your model.
My driver does not support IAS cluster Sirens (yet), so in addition to HE inbuilt Generic Zigbee Siren driver, Gabriele's "Generic Zigbee Siren" is the closest match. I can try to path it in the next week if my time permits.
thank you.
i will be looking forward for your patch driver
BTW since i removed the siren as a device. it does not goes off anymore. so it is the above error i have mentioned.
