Sure l will do again. Will let you know in this post what the results will be.
@kkossev <
This is logging from just now:
dev:2552022-11-13 22:14:36.067errorjava.lang.NullPointerException: Cannot invoke method isAutoOn() on null object on line 515 (method setLevel)
dev:2552022-11-13 22:14:09.501errorjava.lang.NullPointerException: Cannot invoke method isAutoOn() on null object on line 515 (method setLevel)
dev:2552022-11-13 22:13:38.048infoBrightness 01 is 100% (100)
dev:2552022-11-13 22:13:37.986infoSwitch 01 is on
dev:2552022-11-13 22:13:36.559infoBrightness 01 is 100% (100)
dev:2552022-11-13 22:13:36.492infoSwitch 01 is off
dev:2552022-11-13 22:13:14.209infoBrightness 01 is 100% (100)
dev:2552022-11-13 22:13:14.133infoSwitch 01 is on
dev:2552022-11-13 22:13:13.935infoSwitch 01 is on
dev:2552022-11-13 22:13:09.523errorjava.lang.NullPointerException: Cannot invoke method isAutoOn() on null object on line 515 (method setLevel)
dev:2552022-11-13 22:12:59.887infoBrightness 01 is 100% (100)
dev:2552022-11-13 22:12:59.818infoSwitch 01 is off
dev:2552022-11-13 22:12:59.664infoSwitch 01 is off
dev:2552022-11-13 22:12:37.122errorjava.lang.NullPointerException: Cannot invoke method isAutoOn() on null object on line 515 (method setLevel)
dev:2552022-11-13 22:12:16.965infomaxLevel brightness parameter was updated to 100%
dev:2552022-11-13 22:12:14.972infominLevel brightness parameter was updated to 0%
dev:2552022-11-13 22:12:14.849errorjava.lang.NullPointerException: Cannot invoke method onParentSettingsChange() on null object on line 254 (method updated)
dev:2552022-11-13 22:12:14.819info### updating settings for device _TZE200_ip2akl4w [numEps:1, model:TS0601, inClusters:0004,0005,EF00,0000, joinName:Moes Zigbee 1-Gang Dimmer module]
dev:2552022-11-13 22:12:10.177errorjava.lang.NullPointerException: Cannot invoke method multiply() on null object on line 922 (method setLevel)
dev:2552022-11-13 22:12:05.117errorjava.lang.NullPointerException: Cannot invoke method multiply() on null object on line 922 (method setLevel)
dev:2552022-11-13 22:11:55.339errorjava.lang.NullPointerException: Cannot invoke method multiply() on null object on line 935 (method parse)
dev:2552022-11-13 22:11:49.794errorjava.lang.NullPointerException: Cannot invoke method multiply() on null object on line 935 (method parse)
dev:2552022-11-13 22:11:46.278errorjava.lang.NullPointerException: Cannot invoke method multiply() on null object on line 935 (method parse)
dev:2552022-11-13 22:11:45.033errorjava.lang.NullPointerException: Cannot invoke method multiply() on null object on line 935 (method parse)
dev:2552022-11-13 22:11:27.772errorjava.lang.NullPointerException: Cannot invoke method multiply() on null object on line 935 (method parse)
dev:2552022-11-13 22:11:23.179errorjava.lang.NullPointerException: Cannot invoke method multiply() on null object on line 935 (method parse)
dev:2552022-11-13 22:10:48.265debug[raw:catchall: 0104 EF00 01 01 0040 00 45F1 01 00 0000 24 01 040F, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:45F1, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:24, direction:01, data:[04, 0F]]
dev:2552022-11-13 22:10:44.434debug[raw:catchall: 0104 EF00 01 01 0040 00 45F1 01 00 0000 01 01 00D80E04000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:45F1, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, D8, 0E, 04, 00, 01, 00]]
dev:2552022-11-13 22:10:44.381debug[raw:catchall: 0104 EF00 01 01 0040 00 45F1 01 00 0000 01 01 00D71504000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:45F1, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, D7, 15, 04, 00, 01, 01]]
dev:2552022-11-13 22:10:44.314debug[raw:catchall: 0104 EF00 01 01 0040 00 45F1 01 00 0000 01 01 00D60404000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:45F1, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, D6, 04, 04, 00, 01, 00]]
dev:2552022-11-13 22:10:44.265debug[raw:catchall: 0104 EF00 01 01 0040 00 45F1 01 00 0000 01 01 00D50602000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:45F1, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, D5, 06, 02, 00, 04, 00, 00, 00, 00]]
dev:2552022-11-13 22:10:44.211debug[raw:catchall: 0104 EF00 01 01 0040 00 45F1 01 00 0000 01 01 00D40302000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:45F1, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, D4, 03, 02, 00, 04, 00, 00, 00, 00]]
dev:2552022-11-13 22:10:44.154debug[raw:catchall: 0104 EF00 01 01 0040 00 45F1 01 00 0000 01 01 00D305020004000003E8, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:45F1, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, D3, 05, 02, 00, 04, 00, 00, 03, E8]]
dev:2552022-11-13 22:10:44.100debug[raw:catchall: 0104 EF00 01 01 0040 00 45F1 01 00 0000 01 01 00D202020004000003E8, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:45F1, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, D2, 02, 02, 00, 04, 00, 00, 03, E8]]
dev:2552022-11-13 22:10:44.065debugParent Switch ON
dev:2552022-11-13 22:10:44.046debug[raw:catchall: 0104 EF00 01 01 0040 00 45F1 01 00 0000 01 01 00D10101000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:45F1, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, D1, 01, 01, 00, 01, 01]]
dev:2552022-11-13 22:10:38.086infoRefreshing...
dev:2552022-11-13 22:10:38.054errorjava.lang.NullPointerException: Cannot invoke method getAt() on null object on line 83 (method parse)
dev:2552022-11-13 22:10:38.049debug[raw:45F101EF000A00002000, dni:45F1, endpoint:01, cluster:EF00, size:0A, attrId:0000, encoding:20, command:01, value:00, clusterInt:61184, attrInt:0]
dev:2552022-11-13 22:10:38.011errorjava.lang.NullPointerException: Cannot invoke method getAt() on null object on line 83 (method parse)
dev:2552022-11-13 22:10:37.995debug[raw:45F101EF000A00002000, dni:45F1, endpoint:01, cluster:EF00, size:0A, attrId:0000, encoding:20, command:01, value:00, clusterInt:61184, attrInt:0]
dev:2552022-11-13 22:10:37.976debug{executed} 0x45F1 0x01 0xEF00 0x00
dev:2552022-11-13 22:10:37.973debugcomponent refresh 255-04 Moes ZigBee Wall Switch 1/2/3-Gang EP04
dev:2552022-11-13 22:10:37.939errorjava.lang.NullPointerException: Cannot invoke method getAt() on null object on line 83 (method parse)
dev:2552022-11-13 22:10:37.933debug[raw:45F101EF000A00002000, dni:45F1, endpoint:01, cluster:EF00, size:0A, attrId:0000, encoding:20, command:01, value:00, clusterInt:61184, attrInt:0]
dev:2552022-11-13 22:10:37.916infoCreating device 255-04
dev:2552022-11-13 22:10:37.912debug{executed} 0x45F1 0x01 0xEF00 0x00
dev:2552022-11-13 22:10:37.908debugcomponent refresh 255-03 Moes ZigBee Wall Switch 1/2/3-Gang EP03
dev:2552022-11-13 22:10:37.858errorjava.lang.NullPointerException: Cannot invoke method getAt() on null object on line 83 (method parse)
dev:2552022-11-13 22:10:37.857infoCreating device 255-03
dev:2552022-11-13 22:10:37.853debug{executed} 0x45F1 0x01 0xEF00 0x00
dev:2552022-11-13 22:10:37.852debug[raw:45F101EF000A00002000, dni:45F1, endpoint:01, cluster:EF00, size:0A, attrId:0000, encoding:20, command:01, value:00, clusterInt:61184, attrInt:0]
dev:2552022-11-13 22:10:37.850debugcomponent refresh 255-02 Moes ZigBee Wall Switch 1/2/3-Gang EP02
dev:2552022-11-13 22:10:37.783infoCreating device 255-02
dev:2552022-11-13 22:10:37.779debug{executed} 0x45F1 0x01 0xEF00 0x00
dev:2552022-11-13 22:10:37.773debugcomponent refresh 255-01 Moes ZigBee Wall Switch 1/2/3-Gang EP01
dev:2552022-11-13 22:10:37.660infoCreating device 255-01
dev:2552022-11-13 22:10:37.657debugParent createChildDevices
dev:2552022-11-13 22:10:37.656infomodel: _TZE200_ip2akl4w buttons: 4
dev:2552022-11-13 22:10:37.652debugParent deleteChildren
dev:2552022-11-13 22:10:37.651debugParent setupChildDevices
dev:2552022-11-13 22:10:37.650warnDebug logging will be automatically disabled after 30 minutes!
