Tuya Integration - Cloud Devices Won't Add to Hubitat
Integration appears to successfully find the two Tuya devices (Zigbee gateway and zemismart zigbee roller motor). However, continue to see this following message at bottom of integration app:
Newly detected Tuya devices on your LAN will be added to Hubitat shortly. Refresh the list below to check.
Name IP Status
zigbee 有线网关 192.168.1.99 &
Are these devices not supported and/or anymore guidance?
If you're talking about the Tuya Integration introduced in release 2.4.4.129, then I'm all but certain that's just for Tuya wifi devices (switches, multi-plugs, dimmers, CT, and RGBW lights supported currently).
It sounds like that shade motor is zigbee, so it should be paired directly to Hubitat. I have no idea if there's a compatible native driver for it, but I'm sure there is (at least) a community driver option available if you search for it.
There is, in HPM
