Tuya Hub
Hi all,
Question for the brains trust - I have a few Tuya devices controlled via the Smart Life app and I have been using my SmartThings hub to relay command via the Maker API using virtual switches in Hubitat.
This is slow and a pain in the @ss - is there a smarter way to do this please?
What devices do you have?
And it may be useful to provide some screenshots and other details of your existing Maker API setup.
Meross garage is a garage opener
Meross Desk is a Meross smartplug
Furnace is an Genio IR blaster
Downlighs are Mirabella Genio
Kettle is a Kogan device
Feeder is a Genio feeder
SmartThings has an existing integration to both Meross and Smart Life which Hubitat does not have to my knowledge, so the skunkworks looks something like this;
  • Lounge Furnace is a Kasa plug which has a native Hubitat integration.
I suppose that your Tuya devices are WiFi ?
You can try this custom integration : [BETA] Tuya Cloud Driver (Limited device support), but it is not actively supported at the moment.
Thanks - I'll give it a try.
Thank you for the driver and the clear configuration guide.
Tuya cloud correctly linked the below devices, but only the ones in yellow were created as child devices. The Smart IR (and two related virtual devices) and my Breville Dehumidifier are not recognised.
Seven found
Just FYI Broken link here, but realise this is not in prod
The original community developer (bradsjm) of this app is no longer using Hubitat (I'm pretty sure he moved on to HA instead), so any Hubitat stuff on his GitHub (or still in HPM) is not maintained and some stuff may have been taken down.
Found the Dehumidify driver here - works now :slight_smile:
Thanks Hydro
