@holand.ivar thanks for your driver. Means I can get away from the cloud all together.
Seeing that the driver was working fine with the few Globe Plug I had, I decided to purchase a bundle of 4 at Costco ( for 20$ nothing to loose
The new plug are running 3.3, but the payload seem to be bigger. The new plug will react to the command but will fail to report status with an error in the log. Forcing the status in the driver returns the current state.
Here are the plug that work :
Here are the plug that failed to report the status but work ( with the assotiate error).
[error]java.lang.IllegalArgumentException: Text must not be null or empty on line 133 (method parse)
DEBUG log from that device :
[dev:147](http://192.168.1.20/logs#)2023-01-26 20:12:18.184[debug](http://192.168.1.20/logs#)Decryted message: {"dps":{"1":false,"9":0,"38":"memory","40":"relay","41":false,"42":"","43":"","44":""}}
[dev:147](http://192.168.1.20/logs#)2023-01-26 20:12:18.181[debug](http://192.168.1.20/logs#)*********** Decrypting **************
[dev:147](http://192.168.1.20/logs#)2023-01-26 20:12:18.178[debug](http://192.168.1.20/logs#)Assembled payload for decrypt: C0DF0EE616C2D464D92F90CF46044B985CF5EF0D2725CA6D37D7F9D0A0DA697C84515407C1DB3386C3749DFE093B70D036D10047B134F287482E88208BBA9C2E34A1174D82E1BDF2350F0E8A9B3923CD8D88632C4D3B01B8D09463AA0946CDE1
[dev:147](http://192.168.1.20/logs#)2023-01-26 20:12:18.167[debug](http://192.168.1.20/logs#)End of message: 96
[dev:147](http://192.168.1.20/logs#)2023-01-26 20:12:18.157[debug](http://192.168.1.20/logs#)Bytes incoming: 124
[dev:147](http://192.168.1.20/logs#)2023-01-26 20:12:18.156[debug](http://192.168.1.20/logs#)Encrypted message detected
[dev:147](http://192.168.1.20/logs#)2023-01-26 20:12:18.153[debug](http://192.168.1.20/logs#)Raw incoming data: �����d�/��FK�\��
'%�m7��Р�i|�QTa��3��t�� ;p�6�G�4�H.� ���.4�M���5��9#͍�c,M;�Дc� F��x�a:�U
[dev:147](http://192.168.1.20/logs#)2023-01-26 20:12:18.118[debug](http://192.168.1.20/logs#)000055AA000000000000000A0000006C00000000C0DF0EE616C2D464D92F90CF46044B985CF5EF0D2725CA6D37D7F9D0A0DA697C84515407C1DB3386C3749DFE093B70D036D10047B134F287482E88208BBA9C2E34A1174D82E1BDF2350F0E8A9B3923CD8D88632C4D3B01B8D09463AA0946CDE178CD613A0000AA55
[dev:147](http://192.168.1.20/logs#)2023-01-26 20:12:18.117[debug](http://192.168.1.20/logs#)Receiving message from device
[dev:147](http://192.168.1.20/logs#)2023-01-26 20:12:17.542[debug](http://192.168.1.20/logs#)Sending message to 192.168.1.151:6668 msg: 000055AA000000000000000A00000088AE1B60272745F6B6DB63949A1CEA12880B58479AA9913016B8F290E1C5C2443C014396C2CC07E20B799E46BAAD19B17A0B58479AA9913016B8F290E1C5C2443C505B7845FBE7AB5F42B12E89B81635A880CC9F55CF8FA6AE1B5A2607B2084AE8D5FDDC69716B9027171A0F0FF9437131A1097C745D746D462F6A1A44DC32B3055BF9391A0000AA55
[dev:147](http://192.168.1.20/logs#)2023-01-26 20:12:17.540[debug](http://192.168.1.20/logs#)HEX crc: 5bf9391a : 4
[dev:147](http://192.168.1.20/logs#)2023-01-26 20:12:17.538[debug](http://192.168.1.20/logs#)152
[dev:147](http://192.168.1.20/logs#)2023-01-26 20:12:17.358[debug](http://192.168.1.20/logs#)Prefix: 000055AA00000000000000
[dev:147](http://192.168.1.20/logs#)2023-01-26 20:12:17.356[debug](http://192.168.1.20/logs#)136
[dev:147](http://192.168.1.20/logs#)2023-01-26 20:12:17.350[debug](http://192.168.1.20/logs#)AE1B60272745F6B6DB63949A1CEA12880B58479AA9913016B8F290E1C5C2443C014396C2CC07E20B799E46BAAD19B17A0B58479AA9913016B8F290E1C5C2443C505B7845FBE7AB5F42B12E89B81635A880CC9F55CF8FA6AE1B5A2607B2084AE8D5FDDC69716B9027171A0F0FF9437131A1097C745D746D462F6A1A44DC32B305000000000000AA55
[dev:147](http://192.168.1.20/logs#)2023-01-26 20:12:17.347[debug](http://192.168.1.20/logs#)payload after={"devId":"eb96378268c1f41019vrxg","gwId":"eb96378268c1f41019vrxg","uid":"eb96378268c1f41019vrxg","t":"1674781937"}
[dev:147](http://192.168.1.20/logs#)2023-01-26 20:12:17.336[debug](http://192.168.1.20/logs#)ae1b60272745f6b6db63949a1cea12880b58479aa9913016b8f290e1c5c2443c014396c2cc07e20b799e46baad19b17a0b58479aa9913016b8f290e1c5c2443c505b7845fbe7ab5f42b12e89b81635a880cc9f55cf8fa6ae1b5a2607b2084ae8d5fddc69716b9027171a0f0ff9437131a1097c745d746d462f6a1a44dc32b305
[dev:147](http://192.168.1.20/logs#)2023-01-26 20:12:17.332[debug](http://192.168.1.20/logs#)payload before={"devId":"eb96378268c1f41019vrxg","gwId":"eb96378268c1f41019vrxg","uid":"eb96378268c1f41019vrxg","t":"1674781937"}
[dev:147](http://192.168.1.20/logs#)2023-01-26 20:12:17.331[debug](http://192.168.1.20/logs#)33
Not sure if u are still supporting this - just wondering !
