I have a LED driver that should turn off when the 0-10 dimmer is set to 0.
I have a Leviton dimmer switch that claims to be 0-10 connected to the driver. (Bypassing the switch part and just using the dimmer for now)
When I adjust the dimmer to 0, the light is still on. Is this a hardware thing or software thing?
Turns out it was a hardware thing. Tried a different 0-10v dimmer the light would completely shut off when dimming voltage was set to 0.
Dimmer that worked EUControls Zigbee LCM-LV-ZB
system
Closed
3
