Turn off Ecobee using a Basic Rule -- FAILS
I'm trying to setup a Basic rule that will turn off My HVAC when a smoke alarm event is seen.
I got to Basic Rules
I set the event to be any of my three First Alert Smoke Detectors
I say "When Smoke is present"
Now it asks for Action
I select "Control Thermostats"
I see this list of my 2 ecobee thermostats
I click update
I get the following error
Unexpected Error
An unexpected error has occurred trying to load the app. Check Logs for more information.
Error: No signature of method: basicRule10.parseJson() is applicable for argument types: (iava.til.ArravList) values: (floff, cool, heat]. [off, cool, heatIll
and from the logs
app:126
2023-01-10 06:46:59.956 PM
error groovy.lang.MissingMethodException: No signature of method: basicRule10.parseJson() is applicable
for argument types: (java.util.ArrayList) values: Illoff, cool, heat], off, cool, heat]l] on line 1182 (method mainPage)
It never prompted me for the action to take on the thermostat (I wanted to turn it off). It just quit with an error.
I would have expected it to ask me what action.
Additional Info
If I manually select the thermostat device, I can turn it off; so that tells me that it CAN communicate with the thermostat.
Any help would be appreciated.
Which ecobee integration are you using? Built-in, or something else?
Ecobee Integration Version 1.0.2
Tagging @bravenel
The thermostat device is not up to date.
Try this:
