Hi everyone having some issues. I do this fine in HomeSeer today but trying to do it in Hubitat. Basically I have a Hue light that I want to turn on and off from Button 1 on a keypad, basically as a toggle. Press it once the light comes on, press it again it goes off.
I'm using the Button Controller-3.0 app, and first I tried making the action to "toggle a switch." This turns the light on, but doesn't turn it off. However, the odd time it does turn it off, but then it comes right back on.
So I gave up on that and did a Rule Machine. I created 2 of them:
If button 1 is pressed and hue light is off, set hue dimmer value to 80%
If button 1 is pressed and hue light is not off, turn off hue light
This is even weirder, as when I press the button the light turns on, immediately goes off and then comes back on. You press it again, it does the same thing. Depending how long I wait before pushing the button it always has a different outcome.
I want to accomplish this without having a dedicated "Lights Off" button on the keypad and just do it as a toggle like I have it set up in HomeSeer today. What's the proper way to do this?
