I'm trying to setup tts on google home mini (using the Chromecast Integration (beta)) app.
For whatever reason it only plays the first (approximately) 4 seconds of the message when option "Stop after TTS is complete" is enabled. If i disable it the whole message will play just fine.
My experiment:
I created a virtual button and a rule that uses speech device when button is pressed.
The test message is:
At least one window is open for an extended period. A.C. will be turned off in 2 minutes unless all windows are closed.
It always stops around the word "extended" and "period".
Again, it will play the whole message if I disable "Stop after TTS is complete".
By the way, does tts relies on internet connection?
