I am moving into a new house and it has a whole house audio system. The system has RCA inputs. Anyone know of a TTS to RCA device that works in HE?
Do you already have an Alexa device? If it has a 3.5mm audio out, you just need a 3.5mm to RCA adapter. You can find for less than $10. If Alexa doesn't and your audio system doesn't already have Bluetooth, you can buy a BT device like this:
https://www.amazon.com/dp/B016NUTG5K/ref=cm_sw_r_cp_apa_fabc_s4nZFbY7J0A0S
I have successfully used both methods to connect Alexa to home theater system.
Amazon also has an Echo Link with RCA output but a little pricy...
Echo Flex is only $9.99 on Amazon and has 3.5mm jack
