TS0225_LINPTECH Firmware Update
Mine are not really even that old...but have 1.0.5 firmware...I see some pretty old posts that say it needs 1.0.6.
I've looked at several sites and not finding it (yet) Tuya/Moes/Linptech) I'm not really seeing "support" links...is it downloadable somewhere?
I have to reboot them often.
Updating the firmware just gives you the option of turning off the crazy led. It doesn’t solve the problem of needing to reboot them. You need a Tuya hub to update the firmware, which unfortunately does not solve the problem of needing to reboot the device. I think that a lot of people have automated the reboots using either a smart outlet, or the Sonoff Zigbee USB switch. I went with the latter and am using @kkossev’s excellent driver for said switch that enables increasing the Zigbee transmission power, making the usb switch an absolute beast of a repeater (I believe it uses the same zigbee chip as the C-8). I just created a rule to power off every night at 2:30, wait 20 seconds and then power back on.
I’m still using the 3 Linptech mmwave sensors, but moved them to less mission critical areas. I tried the Aqara FP1E sensor, and really like them for not giving false motion events, but they would randomly drop off the mesh. It would sometimes take a couple of weeks or a month, but they would eventually drop. I even set one up right next to a spare HE hub as the hubs only Zigbee device and it dropped off after a few weeks. My solution was getting an Aqara M2 hub for the FP1E sensors and connecting it to HE via Matter. I am very happy with this setup and it has been working flawlessly for about a year now. I have added 2 more FP1E sensors and have not had any problems since.
What an awesome answer. Thanks for taking all that time. All I really use these for is to trigger lights for motion now in two closets. IE - detecting very small motion is not required and they are overkill. It's a real shame an upgrade doesn't fix the problem...and you can't do it through a Hubitat hub.
I had originally bought these to hopefully trigger faster than my old school ones...but they actually were not any faster...or at least not noticeably...and there are other things in that loop that take some time too.
I think I saw some light switches that were ZWAVE but had local motion detection to turn them on too...and had configurable timeouts...that sounds like something like that may be my answer.
Anyway...THANKS again for all the detail!
The combo switches are pretty expensive, but Inovelli and GE/Jasco have been mentioned frequently in the forum, the former having mmwave built in IIRC. Mmwave isn’t generally used for speed, so unless you’re looking at Aqara’s FP300 (which has PIR and mmwave in 1 sensor), you will be better served by going with a PIR sensor. Zigbee is generally the fastest, but Zooz may have some good zwave sensors, not sure. Third reality also has some reasonable Zigbee sensors that are rather bulky, but should be fine for a closet.
Thanks for all that info!
Yeah, these were slower than my old monoprice standard motion detectors
Without too much exception, I generally rather have the product I want no matter the price …so I’ve got some shopping to do to figure out the next step.
Thanks for all the info!
Sounds like you might be using the wrong tool for the application you’re interested in.
PIR (old school) motion sensors trigger faster but they aren’t as sensitive to very small movements.
mmWave sensors aren’t as fast as PIR, but can detect movements that PIR sensors never could.
Right...when I bought these their PR was saying they were faster.
I'm not really a big fan of being constantly bombarded by radar from a close range ...which is funny since I have about 130 or z wave/zigbee devices and wifi chattering 24x7 in the house....but on the other hand...you have every TV/Radio station/Cell phone ...passing through you too...just to name few. :upside_down_face:
Inescapable...but I'm really not as paranoid as that sounds...
What is it that concerns you about mmWave sensors more-so than all the other waves of the electromagnetic spectrum (that are all over the place in your house anyway, as you pointed out)?
I don’t think I’d want the radar array from a navy destroyer in my living room either, but we’re talking about really, really small devices (with correspondingly weak transmiters).
I tried to make it clear that I wasn't really that worried about it at all. Just if they are no faster, more expensive, and emit more...turning on closet lights is a pointless application for them. Old school IR sensors transmit things like z-wave occasionally and when triggered...but have no constant wave output of any kind.
