I have a rule that turns a virtual switch on and off when the blower for my water heater operates which is used in Hubigraphs. I have it operating well in RM but thought I'd try and learn a little about Basic Rules. So far I'm not succeeding, must be a forest for the trees problem. The Basic rule will turn on the switch when power exceeds 25 w but will not turn it off when power drops below 10 w. The logs show that when power drops below the threshold it actually turns the virtual switch on again.
RM
Yes, I had forgotten Basic Rules existed, saw a reminder on FB yesterday so I was trying to recreate a not too complicated but not overly simple rule that I know works. Pretty sure I clicked done numerous times as I played with this but I just gave it another go. I'll advise if that solves it.
Looks to be essentially the same. I rewrote mine exactly as before. I'm curious to see if it works and I somehow managed to corrupt the first one when I was editing it. I'll know in the morning.
Below is the log from the fresh new Basic Rule. When power drops below 10 watts the virtual switch is being turned on instead of off.
@bravenel please see above. Appears to be a bug. Basic Rule doesn't seem to want to turn off a virtual device. Instead it turns it on. If I'm doing it wrong please advise.
Thanks,
Looks to me as though this rule is being re-triggered before the Wait is done, and it never gets to the turn off. At least that is what your logs show. The sequence is event, followed by turn on, followed by wait until below 10. That is what is repeated.
If anything, there is something very odd about why it triggers when power switch power is below 25, as it should not. I tested this yesterday, and for me that test works as expected. But for you, it fails. I don't know why.
Notice that values below 25 do not trigger it, while the one value over 25 did trigger it. What driver is in use for the Zooz power switch? Would you please post the device events from its device page Events button (at top of device page).
OK, the bug appears to be associated with how the Wait is getting setup. I can reproduce the problem once I added the wait to my test app. Will find out why.
Thanks, and all along I've been telling people typos are a feature. bobbyD launched me on the Basic Rule experiment with a recent FB comment. I had completely forgotten about it.
