Hi !
I got a Tuya WZ5 5 in 1 led controller (RGBWW+CCT)
if i put it in RGBW mode and joint in to the hub, it finds the device and proposes " [Tuya Advanced Zigbee RGBW Bulb]" driver from @kkossev
but unfortinately my controller is a TS0504B, not a TS0505B
so whenever i select a color, if I want to change the level, it reverts to CT mode and turns off the RGB leds and lights up the white leds.
in other words, I have no control over the color leds level ![]()
i must not be the only one with this problem.
I did try every other driver the had the string "RGBW" in it's name without success.
the device info I get is this:
fingerprint profileId:"0104", endpointId:"01", inClusters:"0003,0004,0005,0006,1000,0008,0300,EF00,0000", outClusters:"0019,000A", model:"TS0504B", manufacturer:"_TZB210_5jn6an2y"
can anyone help ?
Thanks !
