Trying to add IKEA LED Driver as Generic Zigbee dimmer
Hello,
I've found reports of success using IKEA LED drivers with the Generic Zigbee Dimmer driver in HE.
When I attempt to pair the IKEA device, HE sees the zigbee device and reports "Found Zigbee device with id 680ae2fffe3aa825, initializing...", but it never goes beyond that. There aren't any new devices in my device list.
Has anyone had luck adding an IKEA LED driver. Pictures attached...
IMG_1440|231x500
IMG_1442|666x500
Hi @user117
I added mine about a year ago so I don't remember having any pairing issues.
I am using the Generic Zigbee Bulb driver.
I am using the Advanced Zigbee Bulb driver with the IKEA Led Driver and never had an issue. It has been working fully reliably for a year.
If I recall correctly, this is the driver that the pairing recommended.
But seems as your problem is with the pairing, not with the chosen driver.
Thanks for the replies! I finally was able to get the IKEA device to pair. Just kept resetting it. Probably tried 30 times but finally worked.
