I get the error "expecting '!', found ' ' @ line 1, column 2."
I am not a coder and don't know what that means although, I did try to modify it (blindly). that just produced different errors
I did this once before and don't remember having problems.
All I thought I had to do to get the Child devices back was add a new driver and virtual device but Noooo.
I have a companion Hub now. Maybe somebody can send me a link to the correct device driver, please.
aaiyar
February 10, 2020, 2:59am
2
Hello -
I think it would really help if you could indicate exactly which Logitech device you tried adding and which driver you used?
Is it a Logitech Harmony hub?
Yes, it was a Logitech Harmony hub probably an early version 1, before Logitech bricks it (lol) I thought I'd get a newer one.
I don't remember which driver it was. I had some excellent help and followed his steps. (Obieone ??)
ccoupe
February 10, 2020, 3:32am
4
That error typically comes from a bad paste in the driver/app text box. Often the selected text includes things that aren't the driver - like the whole page and not the driver code. It can also happen if you don't click in the destination box for the code.
ogiewon
February 10, 2020, 4:45am
5
The current Logitech Harmony Hub is supported by my driver on Hubitat. Give it a try.
WARNING - v0.1.20221230 is a BREAKING code change. DO NOT UPGRADE to this new version unless you are willing to spend the time to start anew with your Hamony Hub integration with Hubitat. This new version now uses Hubitat's built-in Generic Component Switch driver, which has the benefit of allowing the Child Activitiy Switch devices to show up in the new Hubitat HomeKit integration.
v0.1.20230311 Added proper support for the push() and hold() commands on the parent device page.
v0.1.20221231 …
