I am hoping for some assistance with an issue I am having. I have 2 LOMP apps running with "Use time restrictions" set to between Sunset -30 and Sunrise 30. However, neither of them are following the restricition. They are both running all day.
Here is the setup for one of them:
Events for Motion Sensor and Light:
Logs for the past couple hours:
dev:202023-09-13 12:31:45.831 PMinfoDownstairs Hallway was turned off [digital]
dev:202023-09-13 12:31:45.830 PMdebugdimmerEvents value:2, type:digital, bin:-10
dev:202023-09-13 12:31:45.828 PMinfoBasicReport value: 2
dev:202023-09-13 12:31:45.824 PMdebugparse description: zw device: 0E, command: 2003, payload: 02 , isMulticast: false
app:1162023-09-13 12:31:45.387 PMdebugTurned off all lights
dev:202023-09-13 12:31:45.374 PMdebugoff()
app:1162023-09-13 12:31:45.367 PMtracegetDevicesToTurnOff(includeExtraOffLights=true)
app:1162023-09-13 12:31:45.365 PMtracescheduledOffHandler
dev:202023-09-13 12:31:16.597 PMinfoDownstairs Hallway was set to 15% [digital]
dev:202023-09-13 12:31:16.595 PMinfoDownstairs Hallway is on [digital]
dev:202023-09-13 12:31:16.594 PMdebugdimmerEvents value:15, type:digital, bin:15
dev:202023-09-13 12:31:16.592 PMinfoBasicReport value: 15
dev:202023-09-13 12:31:16.589 PMdebugparse description: zw device: 0E, command: 2003, payload: 0F , isMulticast: false
app:1162023-09-13 12:31:15.353 PMdebugDimmed all applicable lights
app:1162023-09-13 12:31:15.337 PMtracegetDevicesToTurnOff(includeExtraOffLights=true)
app:1162023-09-13 12:31:15.334 PMtracegetDevicesToTurnOff(includeExtraOffLights=true)
app:1162023-09-13 12:31:15.333 PMdebug Configured to remember...
app:1162023-09-13 12:31:15.332 PMtracecaptureStates
app:1162023-09-13 12:31:15.330 PMtracescheduledDimHandler
app:1162023-09-13 12:30:15.305 PMdebug Dim then off configured; scheduling dim for 60s and off after dim interval
app:1162023-09-13 12:30:15.303 PMtraceperformInactiveAction
app:1162023-09-13 12:30:15.302 PMdebugisOK in isOffKillSwitchOK: true
app:1162023-09-13 12:30:15.300 PMdebugisOffKillSwitchOK()
app:1162023-09-13 12:30:15.299 PMdebugtimeOK = true
app:1162023-09-13 12:30:15.295 PMtraceisTimeOK()
app:1162023-09-13 12:30:15.294 PMtraceluxOK = true
app:1162023-09-13 12:30:15.292 PMdebugMotion inactive and at least one light on
app:1162023-09-13 12:30:15.291 PMtraceverifyNoneOn returning false
app:1162023-09-13 12:30:15.289 PMtraceverifyNoneOn(true)...
app:1162023-09-13 12:30:15.287 PMtraceverifyNoneOn returning false
app:1162023-09-13 12:30:15.285 PMtraceverifyNoneOn(false)...
app:1162023-09-13 12:30:15.284 PMtracemotionHandler: Downstairs Hallway Motion inactive (mode Day [1]) ===
dev:202023-09-13 12:29:52.373 PMinfoDownstairs Hallway was set to 30% [digital]
dev:202023-09-13 12:29:52.371 PMinfoDownstairs Hallway was turned on [digital]
dev:202023-09-13 12:29:52.370 PMdebugdimmerEvents value:30, type:digital, bin:30
dev:202023-09-13 12:29:52.368 PMinfoBasicReport value: 30
dev:202023-09-13 12:29:52.366 PMdebugparse description: zw device: 0E, command: 2003, payload: 1E , isMulticast: false
app:1162023-09-13 12:29:51.132 PMtraceendGrace()
app:1162023-09-13 12:29:51.110 PMtracegetDevicesToTurnOn()...
app:1162023-09-13 12:29:51.108 PMdebug -> now performing setting activations...
app:1162023-09-13 12:29:51.107 PMdebug -> none on, is dimmed, or configured to always turn on, so (re)activating settings... (anyOn = false; dimmed = false; notIfOn = true)
app:1162023-09-13 12:29:51.106 PMdebug action is "onColor"
app:1162023-09-13 12:29:51.104 PMtraceverifyNoneOn returning true
app:1162023-09-13 12:29:51.103 PMtraceverifyNoneOn(false)...
app:1162023-09-13 12:29:51.102 PMtraceperformActiveAction
app:1162023-09-13 12:29:51.100 PMdebugisOK in isOnKillSwitchOK: true
app:1162023-09-13 12:29:51.099 PMdebugisOnKillSwitchOK()
app:1162023-09-13 12:29:51.098 PMtraceluxOK = true
app:1162023-09-13 12:29:51.097 PMdebugtimeOK = true
app:1162023-09-13 12:29:51.093 PMtraceisTimeOK()
app:1162023-09-13 12:29:51.091 PMtraceverifyNoneOn returning true
app:1162023-09-13 12:29:51.090 PMtraceverifyNoneOn(false)...
app:1162023-09-13 12:29:51.066 PMtraceverifyNoneOn returning true
app:1162023-09-13 12:29:51.064 PMtraceverifyNoneOn(false)...
app:1162023-09-13 12:29:51.063 PMtracemotionHandler: Downstairs Hallway Motion active (mode Day [1]) ===
dev:202023-09-13 12:27:37.160 PMinfoDownstairs Hallway was turned off [digital]
dev:202023-09-13 12:27:37.158 PMdebugdimmerEvents value:2, type:digital, bin:-10
dev:202023-09-13 12:27:37.156 PMinfoBasicReport value: 2
dev:202023-09-13 12:27:37.154 PMdebugparse description: zw device: 0E, command: 2003, payload: 02 , isMulticast: false
app:1162023-09-13 12:27:36.716 PMdebugTurned off all lights
dev:202023-09-13 12:27:36.706 PMdebugoff()
app:1162023-09-13 12:27:36.699 PMtracegetDevicesToTurnOff(includeExtraOffLights=true)
app:1162023-09-13 12:27:36.696 PMtracescheduledOffHandler
dev:202023-09-13 12:27:07.948 PMinfoDownstairs Hallway was set to 15% [digital]
dev:202023-09-13 12:27:07.946 PMinfoDownstairs Hallway is on [digital]
dev:202023-09-13 12:27:07.944 PMdebugdimmerEvents value:15, type:digital, bin:15
dev:202023-09-13 12:27:07.942 PMinfoBasicReport value: 15
dev:202023-09-13 12:27:07.938 PMdebugparse description: zw device: 0E, command: 2003, payload: 0F , isMulticast: false
app:1162023-09-13 12:27:06.703 PMdebugDimmed all applicable lights
app:1162023-09-13 12:27:06.684 PMtracegetDevicesToTurnOff(includeExtraOffLights=true)
app:1162023-09-13 12:27:06.681 PMtracegetDevicesToTurnOff(includeExtraOffLights=true)
app:1162023-09-13 12:27:06.680 PMdebug Configured to remember...
app:1162023-09-13 12:27:06.678 PMtracecaptureStates
app:1162023-09-13 12:27:06.677 PMtracescheduledDimHandler
app:1162023-09-13 12:26:06.653 PMdebug Dim then off configured; scheduling dim for 60s and off after dim interval
app:1162023-09-13 12:26:06.651 PMtraceperformInactiveAction
app:1162023-09-13 12:26:06.650 PMdebugisOK in isOffKillSwitchOK: true
app:1162023-09-13 12:26:06.648 PMdebugisOffKillSwitchOK()
app:1162023-09-13 12:26:06.647 PMdebugtimeOK = true
app:1162023-09-13 12:26:06.643 PMtraceisTimeOK()
app:1162023-09-13 12:26:06.642 PMtraceluxOK = true
app:1162023-09-13 12:26:06.641 PMdebugMotion inactive and at least one light on
app:1162023-09-13 12:26:06.639 PMtraceverifyNoneOn returning false
app:1162023-09-13 12:26:06.637 PMtraceverifyNoneOn(true)...
app:1162023-09-13 12:26:06.635 PMtraceverifyNoneOn returning false
app:1162023-09-13 12:26:06.633 PMtraceverifyNoneOn(false)...
app:1162023-09-13 12:26:06.631 PMtracemotionHandler: Downstairs Hallway Motion inactive (mode Day [1]) ===
dev:202023-09-13 12:25:43.007 PMinfoDownstairs Hallway was set to 30% [digital]
dev:202023-09-13 12:25:43.005 PMinfoDownstairs Hallway was turned on [digital]
dev:202023-09-13 12:25:43.004 PMdebugdimmerEvents value:30, type:digital, bin:30
dev:202023-09-13 12:25:43.002 PMinfoBasicReport value: 30
dev:202023-09-13 12:25:42.999 PMdebugparse description: zw device: 0E, command: 2003, payload: 1E , isMulticast: false
app:1162023-09-13 12:25:41.765 PMtraceendGrace()
app:1162023-09-13 12:25:41.740 PMtracegetDevicesToTurnOn()...
app:1162023-09-13 12:25:41.738 PMdebug -> now performing setting activations...
app:1162023-09-13 12:25:41.735 PMdebug -> none on, is dimmed, or configured to always turn on, so (re)activating settings... (anyOn = false; dimmed = false; notIfOn = true)
app:1162023-09-13 12:25:41.733 PMdebug action is "onColor"
app:1162023-09-13 12:25:41.731 PMtraceverifyNoneOn returning true
app:1162023-09-13 12:25:41.729 PMtraceverifyNoneOn(false)...
app:1162023-09-13 12:25:41.727 PMtraceperformActiveAction
app:1162023-09-13 12:25:41.726 PMdebugisOK in isOnKillSwitchOK: true
app:1162023-09-13 12:25:41.724 PMdebugisOnKillSwitchOK()
app:1162023-09-13 12:25:41.722 PMtraceluxOK = true
app:1162023-09-13 12:25:41.721 PMdebugtimeOK = true
app:1162023-09-13 12:25:41.713 PMtraceisTimeOK()
app:1162023-09-13 12:25:41.712 PMtraceverifyNoneOn returning true
app:1162023-09-13 12:25:41.710 PMtraceverifyNoneOn(false)...
app:1162023-09-13 12:25:41.688 PMtraceverifyNoneOn returning true
app:1162023-09-13 12:25:41.686 PMtraceverifyNoneOn(false)...
app:1162023-09-13 12:25:41.685 PMtracemotionHandler: Downstairs Hallway Motion active (mode Day [1]) ===
dev:202023-09-13 12:25:33.618 PMinfoDownstairs Hallway was turned off [digital]
dev:202023-09-13 12:25:33.616 PMdebugdimmerEvents value:2, type:digital, bin:-10
dev:202023-09-13 12:25:33.614 PMinfoBasicReport value: 2
dev:202023-09-13 12:25:33.608 PMdebugparse description: zw device: 0E, command: 2003, payload: 02 , isMulticast: false
app:1162023-09-13 12:25:33.172 PMdebugTurned off all lights
dev:202023-09-13 12:25:33.162 PMdebugoff()
app:1162023-09-13 12:25:33.155 PMtracegetDevicesToTurnOff(includeExtraOffLights=true)
app:1162023-09-13 12:25:33.152 PMtracescheduledOffHandler
dev:202023-09-13 12:25:04.389 PMinfoDownstairs Hallway was set to 15% [digital]
dev:202023-09-13 12:25:04.387 PMinfoDownstairs Hallway is on [digital]
dev:202023-09-13 12:25:04.385 PMdebugdimmerEvents value:15, type:digital, bin:15
dev:202023-09-13 12:25:04.383 PMinfoBasicReport value: 15
dev:202023-09-13 12:25:04.381 PMdebugparse description: zw device: 0E, command: 2003, payload: 0F , isMulticast: false
app:1162023-09-13 12:25:03.145 PMdebugDimmed all applicable lights
app:1162023-09-13 12:25:03.129 PMtracegetDevicesToTurnOff(includeExtraOffLights=true)
app:1162023-09-13 12:25:03.126 PMtracegetDevicesToTurnOff(includeExtraOffLights=true)
app:1162023-09-13 12:25:03.124 PMdebug Configured to remember...
app:1162023-09-13 12:25:03.123 PMtracecaptureStates
app:1162023-09-13 12:25:03.122 PMtracescheduledDimHandler
app:1162023-09-13 12:24:03.089 PMdebug Dim then off configured; scheduling dim for 60s and off after dim interval
app:1162023-09-13 12:24:03.087 PMtraceperformInactiveAction
app:1162023-09-13 12:24:03.086 PMdebugisOK in isOffKillSwitchOK: true
app:1162023-09-13 12:24:03.085 PMdebugisOffKillSwitchOK()
app:1162023-09-13 12:24:03.084 PMdebugtimeOK = true
app:1162023-09-13 12:24:03.080 PMtraceisTimeOK()
app:1162023-09-13 12:24:03.078 PMtraceluxOK = true
app:1162023-09-13 12:24:03.075 PMdebugMotion inactive and at least one light on
app:1162023-09-13 12:24:03.074 PMtraceverifyNoneOn returning false
app:1162023-09-13 12:24:03.071 PMtraceverifyNoneOn(true)...
app:1162023-09-13 12:24:03.068 PMtraceverifyNoneOn returning false
app:1162023-09-13 12:24:03.065 PMtraceverifyNoneOn(false)...
app:1162023-09-13 12:24:03.055 PMtracemotionHandler: Downstairs Hallway Motion inactive (mode Day [1]) ===
dev:202023-09-13 12:23:33.684 PMinfoDownstairs Hallway was set to 30% [digital]
dev:202023-09-13 12:23:33.682 PMinfoDownstairs Hallway was turned on [digital]
dev:202023-09-13 12:23:33.680 PMdebugdimmerEvents value:30, type:digital, bin:30
dev:202023-09-13 12:23:33.678 PMinfoBasicReport value: 30
dev:202023-09-13 12:23:33.675 PMdebugparse description: zw device: 0E, command: 2003, payload: 1E , isMulticast: false
app:1162023-09-13 12:23:32.433 PMtraceendGrace()
app:1162023-09-13 12:23:32.417 PMtracegetDevicesToTurnOn()...
app:1162023-09-13 12:23:32.415 PMdebug -> now performing setting activations...
app:1162023-09-13 12:23:32.414 PMdebug -> none on, is dimmed, or configured to always turn on, so (re)activating settings... (anyOn = false; dimmed = false; notIfOn = true)
app:1162023-09-13 12:23:32.413 PMdebug action is "onColor"
app:1162023-09-13 12:23:32.411 PMtraceverifyNoneOn returning true
app:1162023-09-13 12:23:32.410 PMtraceverifyNoneOn(false)...
app:1162023-09-13 12:23:32.408 PMtraceperformActiveAction
app:1162023-09-13 12:23:32.407 PMdebugisOK in isOnKillSwitchOK: true
app:1162023-09-13 12:23:32.406 PMdebugisOnKillSwitchOK()
app:1162023-09-13 12:23:32.405 PMtraceluxOK = true
app:1162023-09-13 12:23:32.404 PMdebugtimeOK = true
app:1162023-09-13 12:23:32.399 PMtraceisTimeOK()
app:1162023-09-13 12:23:32.398 PMtraceverifyNoneOn returning true
app:1162023-09-13 12:23:32.393 PMtraceverifyNoneOn(false)...
app:1162023-09-13 12:23:32.372 PMtraceverifyNoneOn returning true
app:1162023-09-13 12:23:32.371 PMtraceverifyNoneOn(false)...
app:1162023-09-13 12:23:32.369 PMtracemotionHandler: Downstairs Hallway Motion active (mode Day [1]) ===
dev:202023-09-13 12:23:05.420 PMwarndescription logging is: true
dev:202023-09-13 12:23:05.419 PMwarndebug logging is: true
dev:202023-09-13 12:23:05.418 PMinfoupdated...
dev:202023-09-13 12:22:25.926 PMinfoDownstairs Hallway was turned off [digital]
app:1162023-09-13 12:22:25.488 PMdebugTurned off all lights
app:1162023-09-13 12:22:25.470 PMtracegetDevicesToTurnOff(includeExtraOffLights=true)
app:1162023-09-13 12:22:25.468 PMtracescheduledOffHandler
dev:202023-09-13 12:21:56.695 PMinfoDownstairs Hallway is 15% [digital]
dev:202023-09-13 12:21:56.693 PMinfoDownstairs Hallway is on [digital]
app:1162023-09-13 12:21:55.454 PMdebugDimmed all applicable lights
app:1162023-09-13 12:21:55.438 PMtracegetDevicesToTurnOff(includeExtraOffLights=true)
app:1162023-09-13 12:21:55.435 PMtracegetDevicesToTurnOff(includeExtraOffLights=true)
app:1162023-09-13 12:21:55.433 PMdebug Configured to remember...
app:1162023-09-13 12:21:55.432 PMtracecaptureStates
app:1162023-09-13 12:21:55.431 PMtracescheduledDimHandler
app:1162023-09-13 12:20:55.396 PMdebug Dim then off configured; scheduling dim for 60s and off after dim interval
app:1162023-09-13 12:20:55.394 PMtraceperformInactiveAction
app:1162023-09-13 12:20:55.392 PMdebugisOK in isOffKillSwitchOK: true
app:1162023-09-13 12:20:55.391 PMdebugisOffKillSwitchOK()
app:1162023-09-13 12:20:55.390 PMdebugtimeOK = true
app:1162023-09-13 12:20:55.384 PMtraceisTimeOK()
app:1162023-09-13 12:20:55.383 PMtraceluxOK = true
app:1162023-09-13 12:20:55.381 PMdebugMotion inactive and at least one light on
app:1162023-09-13 12:20:55.378 PMtraceverifyNoneOn returning false
app:1162023-09-13 12:20:55.375 PMtraceverifyNoneOn(true)...
app:1162023-09-13 12:20:55.372 PMtraceverifyNoneOn returning false
app:1162023-09-13 12:20:55.370 PMtraceverifyNoneOn(false)...
app:1162023-09-13 12:20:55.369 PMtracemotionHandler: Downstairs Hallway Motion inactive (mode Day [1]) ===
app:1162023-09-13 12:20:20.006 PMtraceverifyNoneOn returning false
app:1162023-09-13 12:20:20.005 PMtraceverifyNoneOn(false)...
app:1162023-09-13 12:20:19.978 PMtraceverifyNoneOn returning false
app:1162023-09-13 12:20:19.976 PMtraceverifyNoneOn(false)...
app:1162023-09-13 12:20:19.975 PMtracemotionHandler: Downstairs Hallway Motion active (mode Day [1]) ===
app:1162023-09-13 12:19:00.772 PMdebugDownstairs Hallway Motion (Nights) initialized.
app:1162023-09-13 12:19:00.736 PMtraceendGrace()
app:1162023-09-13 12:19:00.710 PMtraceDownstairs Hallway Motion (Nights) initializing...
app:1162023-09-13 12:19:00.709 PMtraceDownstairs Hallway Motion (Nights) updated
dev:202023-09-13 12:18:49.396 PMinfoDownstairs Hallway was set to 15% [digital]
dev:202023-09-13 12:18:49.393 PMinfoDownstairs Hallway is on [digital]
app:1162023-09-13 12:18:48.148 PMdebugDimmed all applicable lights
app:1162023-09-13 12:18:48.128 PMtracegetDevicesToTurnOff(includeExtraOffLights=true)
app:1162023-09-13 12:18:48.119 PMtracegetDevicesToTurnOff(includeExtraOffLights=true)
app:1162023-09-13 12:18:48.118 PMdebug Configured to remember...
app:1162023-09-13 12:18:48.114 PMtracecaptureStates
app:1162023-09-13 12:18:48.112 PMtracescheduledDimHandler
app:1162023-09-13 12:17:48.089 PMdebug Dim then off configured; scheduling dim for 60s and off after dim interval
app:1162023-09-13 12:17:48.087 PMtraceperformInactiveAction
app:1162023-09-13 12:17:48.086 PMdebugisOK in isOffKillSwitchOK: true
app:1162023-09-13 12:17:48.085 PMdebugisOffKillSwitchOK()
app:1162023-09-13 12:17:48.083 PMdebugtimeOK = true
app:1162023-09-13 12:17:48.080 PMtraceisTimeOK()
app:1162023-09-13 12:17:48.079 PMtraceluxOK = true
app:1162023-09-13 12:17:48.078 PMdebugMotion inactive and at least one light on
app:1162023-09-13 12:17:48.076 PMtraceverifyNoneOn returning false
app:1162023-09-13 12:17:48.074 PMtraceverifyNoneOn(true)...
app:1162023-09-13 12:17:48.070 PMtraceverifyNoneOn returning false
app:1162023-09-13 12:17:48.062 PMtraceverifyNoneOn(false)...
app:1162023-09-13 12:17:48.055 PMtracemotionHandler: Downstairs Hallway Motion inactive (mode Day [1]) ===
app:1162023-09-13 12:17:27.297 PMtraceverifyNoneOn returning false
app:1162023-09-13 12:17:27.295 PMtraceverifyNoneOn(false)...
app:1162023-09-13 12:17:27.231 PMtraceverifyNoneOn returning false
app:1162023-09-13 12:17:27.223 PMtraceverifyNoneOn(false)...
app:1162023-09-13 12:17:27.216 PMtracemotionHandler: Downstairs Hallway Motion active (mode Day [1]) ===
app:1162023-09-13 12:17:01.034 PMdebug Dim then off configured; scheduling dim for 60s and off after dim interval
app:1162023-09-13 12:17:01.031 PMtraceperformInactiveAction
app:1162023-09-13 12:17:01.030 PMdebugisOK in isOffKillSwitchOK: true
app:1162023-09-13 12:17:01.029 PMdebugisOffKillSwitchOK()
app:1162023-09-13 12:17:01.028 PMdebugtimeOK = true
app:1162023-09-13 12:17:01.023 PMtraceisTimeOK()
app:1162023-09-13 12:17:01.022 PMtraceluxOK = true
app:1162023-09-13 12:17:01.020 PMdebugMotion inactive and at least one light on
app:1162023-09-13 12:17:01.019 PMtraceverifyNoneOn returning false
app:1162023-09-13 12:17:01.017 PMtraceverifyNoneOn(true)...
app:1162023-09-13 12:17:01.015 PMtraceverifyNoneOn returning false
app:1162023-09-13 12:17:01.013 PMtraceverifyNoneOn(false)...
app:1162023-09-13 12:17:01.012 PMtracemotionHandler: Downstairs Hallway Motion inactive (mode Day [1]) ===
app:1162023-09-13 12:16:40.160 PMtraceverifyNoneOn returning false
app:1162023-09-13 12:16:40.158 PMtraceverifyNoneOn(false)...
app:1162023-09-13 12:16:40.113 PMtraceverifyNoneOn returning false
app:1162023-09-13 12:16:39.907 PMtraceverifyNoneOn(false)...
app:1162023-09-13 12:16:39.901 PMtracemotionHandler: Downstairs Hallway Motion active (mode Day [1]) ===
app:1162023-09-13 12:15:48.442 PMdebug Dim then off configured; scheduling dim for 60s and off after dim interval
app:1162023-09-13 12:15:48.440 PMtraceperformInactiveAction
app:1162023-09-13 12:15:48.438 PMdebugisOK in isOffKillSwitchOK: true
app:1162023-09-13 12:15:48.437 PMdebugisOffKillSwitchOK()
app:1162023-09-13 12:15:48.435 PMdebugtimeOK = true
app:1162023-09-13 12:15:48.429 PMtraceisTimeOK()
app:1162023-09-13 12:15:48.427 PMtraceluxOK = true
app:1162023-09-13 12:15:48.425 PMdebugMotion inactive and at least one light on
app:1162023-09-13 12:15:48.423 PMtraceverifyNoneOn returning false
app:1162023-09-13 12:15:48.420 PMtraceverifyNoneOn(true)...
app:1162023-09-13 12:15:48.417 PMtraceverifyNoneOn returning false
app:1162023-09-13 12:15:48.415 PMtraceverifyNoneOn(false)...
app:1162023-09-13 12:15:48.413 PMtracemotionHandler: Downstairs Hallway Motion inactive (mode Day [1]) ===
dev:202023-09-13 12:15:34.639 PMinfoDownstairs Hallway was set to 30% [digital]
dev:202023-09-13 12:15:34.637 PMinfoDownstairs Hallway was turned on [digital]
app:1162023-09-13 12:15:33.302 PMtraceendGrace()
app:1162023-09-13 12:15:33.232 PMtracegetDevicesToTurnOn()...
app:1162023-09-13 12:15:33.231 PMdebug -> now performing setting activations...
app:1162023-09-13 12:15:33.229 PMdebug -> none on, is dimmed, or configured to always turn on, so (re)activating settings... (anyOn = false; dimmed = false; notIfOn = true)
app:1162023-09-13 12:15:33.228 PMdebug action is "onColor"
app:1162023-09-13 12:15:33.226 PMtraceverifyNoneOn returning true
app:1162023-09-13 12:15:33.225 PMtraceverifyNoneOn(false)...
app:1162023-09-13 12:15:33.223 PMtraceperformActiveAction
app:1162023-09-13 12:15:33.222 PMdebugisOK in isOnKillSwitchOK: true
app:1162023-09-13 12:15:33.221 PMdebugisOnKillSwitchOK()
app:1162023-09-13 12:15:33.220 PMtraceluxOK = true
app:1162023-09-13 12:15:33.219 PMdebugtimeOK = true
app:1162023-09-13 12:15:33.215 PMtraceisTimeOK()
app:1162023-09-13 12:15:33.214 PMtraceverifyNoneOn returning true
app:1162023-09-13 12:15:33.212 PMtraceverifyNoneOn(false)...
app:1162023-09-13 12:15:33.194 PMtraceverifyNoneOn returning true
app:1162023-09-13 12:15:33.192 PMtraceverifyNoneOn(false)...
app:1162023-09-13 12:15:33.191 PMtracemotionHandler: Downstairs Hallway Motion active (mode Day [1]) ===
app:1162023-09-13 11:01:37.582 AMtracescheduledGraceEndHandler()
dev:202023-09-13 11:01:08.003 AMinfoDownstairs Hallway was turned off [digital]
app:1162023-09-13 11:01:07.592 AMdebugTurned off all lights
app:1162023-09-13 11:01:07.591 AMdebug Entered grace period
app:1162023-09-13 11:01:07.559 AMtracestartGrace()
app:1162023-09-13 11:01:07.558 AMdebug Grace period configured for 30 seconds
app:1162023-09-13 11:01:07.538 AMtracegetDevicesToTurnOff(includeExtraOffLights=true)
app:1162023-09-13 11:01:07.535 AMtracescheduledOffHandler
dev:202023-09-13 11:00:38.791 AMinfoDownstairs Hallway was set to 15% [digital]
dev:202023-09-13 11:00:38.789 AMinfoDownstairs Hallway is on [digital]
app:1162023-09-13 11:00:37.549 AMdebugDimmed all applicable lights
app:1162023-09-13 11:00:37.529 AMtracegetDevicesToTurnOff(includeExtraOffLights=true)
app:1162023-09-13 11:00:37.522 AMtracegetDevicesToTurnOff(includeExtraOffLights=true)
app:1162023-09-13 11:00:37.521 AMdebug Configured to remember...
