Trouble Resetting Linear WT00Z-1 Dimmer
Hi all. I recently moved into a new house that has Linear brand dimmers (the one that I pulled out of the wall had a model code WT00Z-1). I'm trying to figure out how to reset them so I can pair with my hub. I found an instruction manual online, but it doesn't appear to have specific directions to initiate a factory reset.
Am I missing something obvious here? Any insight is appreciated.
Welcome to the community!
According to this manual it's a 300 series device so you'll probably need to get your hub quite close during exclusion/inclusion.
Other than that, it should be a simple double tap (run remove first):
Thanks for the response, which got me started. I've successfully paired most of the lights thats are physically close to the hub. Just so I underatand, do I have to run around the house with the hub on the end of a ridiculously long ethernet cable to pair the more remote devices?
