I have a trigger based on a contact staying open for 60 seconds. I want to change that delay to be a global variable so I change it from a dashboard. I can't see a way to select a variable for the seconds. What trigger type do I need to use to set this up?
From what I can see, using a Hub Variable as the “stays” value is not an option that is available at this time.
Tagging @bravenel in case it might be an option for a future release.
Triggering the rule for the contact opening then using a Wait for door opened for a variable duration might be a viable work around.
Use Wait for expression
Wait for Expression: (R)Back Door contact opened --> duration: DoorOpenWait(0:02:00)
