I have 2 Treatlife Smart water leak sensors but they don't appear to be reporting battery level data in Hubitat.
It appears they will if you use the Treatlife hub and app.
Does anyone know if Hubitat will show battery life data for these sensors?
Maybe we need the proper driver?
Thanks, Steve
Looks like they are zigbee? What drivers have you tried using? Did you press configure on the driver?
Yes, Zigbee.
The driver is set to Generic Zigbee Moisture Sensor. And at this point I don't remember if it found that driver automatically or if I picked.
When I click configure in the device settings it doesn't do anything.
Regarding this same zigbee Treatlife Water Leak sensor, I have 2 of these and have added them to Amazon Echo Skill in HE.
However, they don't show up in the Alexa app.
Is anyone else using these successfully in Alexa?
Wondering if I need to remove them from HE and start over.
Thanks, Stevenr
Leak sensors don't show in Alexa unless they have some other attribute that does (like temperature monitoring or a contact switch).
If you wish to do Alexa actions on them you can create a virtual switch, and rules that set/clear it based on the leak sensor state. Expose that virtual to Alexa. This is what I do.
