Yesterday my Hubitat was unresponsive.
I then rebooted it and I noticed that there was an update available.
I upgraded from 2.1.7.127 to 2.1.8.115 now my transitions are not working anymore. It just jumps from the starting scene to the ending scene. I rolled back to 2.1.7.127 and it worked again. I then upgraded to 2.1.8.115 again and the first transition worked, but then the following ones did not work anymore.
I've rolled back to 2.1.7.127 again... All seems to be working now...
I have just tested and the transitions are still not working on the latest update. I only have Philips Hue lamps. At the scheduled time, the transition just jumps from the starting scene to the ending scene.
No hurry, I'm running fine on 2.1.7.127 - but is this still on your todo list? I'm scared that I will not be able to upgrade in the future, when it's needed...
Thank you kindly, I know that you guys are extremely busy, I don't want to impose.
If I could test anything for you, I'll be glad to help.
Probably not a lot of people using this yet. I plan to now that my setup is stable, but I didn't want to before because I was having slowdowns and didn't want to give the hub more to do. I appreciate you finding this and bringing it to Bruce's attention so it can be fixed
I see the fix listed in the 2.1.9 release notes. Does application of the fix require any user intervention, or will existing Scene Transitions with color / color temperature changes just start working again?
