It's reassuring to hear that a single Hubitat controller, particularly the C-8 Pro with its enhanced memory and CPU, should be capable of managing my system of 200 devices effectively.
Thank you
I'm located in Canada, I see that they have a different hubs for the "USA" and "North America" ... I'm curious about the difference between the two hubs. Given that they should have the same frequency, what distinguishes them from each other?
Are you suggesting that by learning Node-RED, I could install it on my Windows computer to manage all my automation rules and programming logic there? I assume this would alleviate the processing load from my Hubitat controller and utilize the capabilities of my computer for handling complex automation tasks. If so, would adopting this practice be advisable, or could it potentially complicate my setup unnecessarily? (I mean, if it was Vera, I would definitely pursue this approach, as offloading processing tasks off Vera was essential due to the limited CPU power of the Vera controllers. However, I'm curious if a similar strategy would be necessary with Hubitat)
i have over 200 devices if you count both zwave and zigbee on a single c8 pro.. i also had them on a c7. and c8 the issue with the c7/c8 was memory issues after a week or two.. c8 pro alleviates that.
only about 100 are zwave however.
the key with doing it with a single hub is a strong mesh and placment.. make sure it is placed in the center of the house both up/downstairs wise and length wise.. to get coverage in all areas.
Node-Red runs on top of NodeJS, which is the base for dozens of useful home automation tools. NodeJS runs on any modern computer from a RaspberryPi to a Mac, Windows or Linux. The only criteria in this case is that it be installed to an always on computer.
Because it runs externally to Hubitat, YOU get to determine the CPU and Memory capabilities.
"necessary" is an objective word and it is not necessary. You have, however, a good grasp of the benefits.
In the end, they are not that different, they both have a database of devices, and it includes the unique device ID, the address of the device in either the Zigbee or Z-Wave world and the name us non-silicon based devices use to identify them.
When you look at the quasi backend, like when you export a rule, it is still referencing the unique ID. Ultimately, I suspect that there's a "find and replace" happening in the background when you swap a device.
Also, when you look into two of the main built in automation tools; either Rule Machine or Simple Automation Rules, there is a copy/export option. When you copy a rule, one of the steps is that you get a prompt of the devices in that rule and the ability to select from your list of devices of similar type to change it to.
As an example you have a rule that when you open the Front Door then Light A turns on. You can copy this rule and change it to Back Door and Light B.
and I would say to your comment..
"allow me to gradually replace the virtual devices with real Z-Wave devices without needing to adapt any programming."
the term without is a bit strong; I would say minimal adaption, but I suspect you already know that.
"I currently do not have any zigbee devices, 99% of my devices are Z-Wave. I assume Hubitat can handle all standard Z-Wave devices, right? I'm hoping to avoid any unexpected surprises in compatibility (for example, my Vera controller did have some small issues with some 'Homeseer Z-Wave devices,' although nothing major, mostly poor battery level reporting)
In terms of DSC interface,I've setup "Envisalink" board to "transmit" all the alarm devices to Hubitat.
(THere is a custom interface to Envisalink boards).
In my search for information on integrating my roller blinds controlled by the RFXCOM RFXtrx433XL device with my future Hubitat smart home setup, I haven't been able to find official documentation. However, based on a few old posts I came across, it seems that RFXCOM 433 may not be supported by Hubitat... Can anyone confirm if this is still the case or if there have been any updates regarding RFXCOM compatibility with Hubitat?
A single Z-Wave network can support up to 232 devices, with up to 4 hops
Hmmm, is this true? It seems to me that only 1 hub might be too tight for my setup to
If you are close to 232 then I would consider a second hub just from the ZWave imposed limit standpoint. Processing power wise one hub would normally be sufficient. @bcopeland is the resident ZWave wizard if you need to do a deep dive.
Hubitat may be able to work with these old devices. But you should really replace them. All they do is create opportunities for frustration, especially with such a large device count.
Given the extensive list of devices, I’m curious about the compatibility of these devices with Hubitat. I’m wondering if anyone here has experience with integrating similar devices into their Hubitat setup. Specifically, I’d like to know:
Where can I find reliable information about the compatibility of these devices with Hubitat?
Based on your experience, how much trouble should I expect in integrating these devices into Hubitat?
Any insights or advice you can provide would be greatly appreciated.
Anything that uses the standard zwave protocol will not be an issue
(The device may pair as something else, but all you have to do is change the driver)
I see you have some GE/Jasco and Leviton devices in your list. In general, these do work with Hubitat. However, I would like to caution you about OLDER generations of equipment.
Earlier Z-Wave devices from GE, the nonZ-Wave Plus devices, do not report manual/physical status changes reliably to Hubitat. As such, this often becomes a source of frustration for users who have these devices. While Hubitat can 'poll' these devices periodically for status updates, many users find that solution unsatisfactory and simply end up replacing these old devices with new, modern devices.
Also, early Leviton Z-Wave devices may have a similar issue. However, I seem to recall that many of these devices can have their firmware upgraded which improves/resolves their performance.
