Hi all,
Long time listener, first time caller
A few months ago, I upgrade from the C7 to the C8, everything has been working as expected. Earlier today, I noticed a device was on, that is usually off. The device is connected to an Ikea Tradfri outlet. The outlet is on a power strip with two other Tradfri outlets controlling some lights and such.
Some background - I have probably 40+ devices in my hub (with quite a few Tradfri outlets). There are no custom jobs that touch this outlet. This outlet is located directly next to some other outlets that were purchased at the same time a few years ago. I can turn the others on and off. The hub is on version: 2.3.5.152
What I have tried:
- Changing to a generic device type, saving, going back, changing back to the built-in ikea driver.
- Hitting configure, in every iteration / combination you can imagine.
- I was going to try install a custom driver but since the others are working fine, I don't think it's that.
- I restarted the hub, no dice.
What I noticed:
- If I turn on one of the other outlets on the same strip, I will see "some device bla bla turned on" in the logs. When I turn this outlet on, I just see: "on() called..." like it's trying to call on, without a device id.
- when I click configure this is what happens in the logs:
refresh...
configure...
it doesn't do anything and immediately goes back to refresh. - the bin state is 1 : not sure what that means, but the other outlets the bin state is -1.
I could remove the outlet and re-pair it but:
- its not really in a super accessible place so I'd prefer to understand what happened and figure out how to prevent it from happening again.
- I'd also like to know when something has gone wrong like this. Is there some sort of automated way to say "something has changed in the way this device communicates" ? I know i could setup all kinds of notifications like - this device that is usually off is suddenly on for more than x mins, but thats not really helpful, it clutters the apps unnecessarily.
Anyone have any ideas? Thank you!
