All the drivers I tested, the pedro garcia's driver is actualy working, including colors. But only if you use the attribute "set color by name": red, orange, yellow, green, cyan, indigo, blue, fuchsia, bright pink, white. It still does give some errors when using the other preset color commands (like set blue). So basically if you use the by name colors in your RM your are fine.
