I've got this rule to adjust my hub variable (hubDimmerLevelDS) if I manually adjust the dimmer level of a virtual dimmer (Downstairs). It's a Rule Machine 5.0 rule. This rule was working fine in RM 4.0, with global variables, but I wanted to see if I get some efficiency from hub variables instead of global variables.
It doesn't seem to update the hub variable, though. Here is what the log says:
![image](https://community.hubitat.com/uploads/default/original/3X/6/2/6206fc0901326adb1ffd4895ca1131d0b3e0728f.png)
I tested setting the rule to a fixed value instead of using Track Dim, and that worked fine. The issue appears when using Track Dim.
I am aware that I could use the connector to achieve this directly but I have to have a separate virtual dimmer to get around the issue of changing dimmer level values turning switches on. I can show the other 4 rules I have to get around this, if you need them, but I think I have my only issue narrowed down to the description above.
Thanks in advance,
Jon
