Does any one know which device type to setup TPLink ms100 motion sensor?
A previous post suggested "Choose the generic motion sensor device and after you pair them, remove the batteries for a reset and all will be OK." However, in the current version, there are 'Generic Component Motion Sensor', 'Generic Zigbee Motion Sensor', and 'Generic Z-wave motion sensor'. The MS100 motion sensor can be discovered as a Zigbee device. But it does not report any events.
The motion sensor seems to response to motion. A blue led on the front blinks when a motion is detected.
Ok, 'Generic Zigbee Motion Sensor (no temp)' seems to work. Hub reports only a battery status of 100. But there is no event logged. A simple rule to turn on a smart bulb does not work either. The same bulb can be turned on by a smart contact sensor. Any thoughts? Thanks!
Right, I picked Generic Zigbee Motion Sensor (no temp)'. It does report a battery status of 100. But that's it. I don't see any events logged. The motion sensor itself does flash its blue LED when a motion is triggered. Any suggestions? Thanks!
Hubitat hub also reported last battery reading time which is 1638754597. This converts to the time when I first set it up. It feels like that the sensor lost communication to the hub after the very initial communication.
Yes I would. They have worked perfectly for about a year now. Just check the measurements, they are a bit large. They sense motion but nothing else. No temp or humidity or anything.
