Am I missing something on how to put a switch on the EZ Dashboard so that I can simply press the tile to toggle it on/off?
If I can manage to click the (barely visible) three dots in the upper right corner, it pops up a model window where I can toggle the switch, but it would be way easier if I could just tap anywhere on the tile to toggle it.
That should be how it works now. What are you seeing? (You might have to hit the icon; I guess for me there isn't much else.) If not, are you sure your device is responding to the commands? Testing with a virtual device would rule that problem out.
