Tiny UI bug in Rule Machine
Just the tiniest but in the UI for rule machine, it looks like there needs to be a line break added either before the "Scenes per mode" or after the "Dimmers per mode". Very picky but figured I'd tell you. Thanks!
Its not just there it's also in temperature per mode.
@bravenel her is another little UI break but in RM
after work at home 100 there should be a new line before colour temperature.
EDIT: by the way this is on the final page. all other steps it looks correct and is on its correct line.
Found and fixed. Thanks.
