Sorry it has taken so long to get back to this issue but it started working for a while. It just started messing up again so I was able to get a log.
First to address some of the other comments.
- I'm pretty sure I have all the conditionals correct and with the correct end-if.
- The symptoms were that the wrong temperature was being set on the thermostat
- I have thought about modes but I am tracking and looking at three different conditions:
- Is everyone gone?
- Are we in bed?
- Is it dark outside?
- These are not mutually exclusive so modes don't really work well
Anyway, on to the update.
I recently rebooted hubitat and it started acting incorrectly again. I don't know if rebooting is what caused it to start acting up or not though. It may be coincidence.
I was able to get a log:
dev:3712019-11-13 11:20:46.454 pm infoLiving Room Motion is inactive
dev:3712019-11-13 11:20:34.280 pm infoLiving Room Motion is inactive
dev:3712019-11-13 11:20:31.432 pm infoLiving Room Motion is active
dev:3672019-11-13 11:20:31.392 pm debugLiving Room Motion
dev:3712019-11-13 11:20:30.091 pm infoLiving Room Motion is inactive
dev:392019-11-13 11:20:25.752 pm infoHome Thermostat thermostatSetpoint is 71°F
dev:392019-11-13 11:20:20.828 pm infoHome Thermostat temperature is 73°F
dev:392019-11-13 11:20:20.826 pm infoHome Thermostat temperature is 73°F
dev:392019-11-13 11:20:20.766 pm infoHome Thermostat thermostatOperatingState is idle
dev:392019-11-13 11:20:20.746 pm infoHome Thermostat thermostatOperatingState is idle
dev:392019-11-13 11:20:20.692 pm infoHome Thermostat heatingSetpoint is 71°F
dev:392019-11-13 11:20:20.681 pm infoHome Thermostat heatingSetpoint is 71°F
dev:3712019-11-13 11:20:19.381 pm infoLiving Room Motion is inactive
dev:3712019-11-13 11:20:15.069 pm infoLiving Room Motion is active
dev:3672019-11-13 11:20:15.048 pm debugLiving Room Motion
dev:392019-11-13 11:19:28.482 pm infoHome Thermostat thermostatSetpoint is 71°F
dev:392019-11-13 11:19:25.320 pm infoHome Thermostat thermostatOperatingState is idle
dev:972019-11-13 11:19:24.745 pm warnCommandResponse skipped clusterId:0006, descMap:[raw:catchall: 0000 0006 00 00 0040 00 5A87 00 00 0000 00 00 02FDFF040101190000, profileId:0000, clusterId:0006, clusterInt:6, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:5A87, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[02, FD, FF, 04, 01, 01, 19, 00, 00]]
dev:972019-11-13 11:19:24.733 pm debugparseCommandResponse: [raw:catchall: 0000 0006 00 00 0040 00 5A87 00 00 0000 00 00 02FDFF040101190000, profileId:0000, clusterId:0006, clusterInt:6, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:5A87, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[02, FD, FF, 04, 01, 01, 19, 00, 00]]
dev:392019-11-13 11:19:23.452 pm infoHome Thermostat coolingSetpoint is 73°F
dev:972019-11-13 11:19:23.111 pm infoFront Door Lock battery is 73%
dev:972019-11-13 11:19:23.107 pm debugparseAttributeResponse: [raw:5A870100010821002049, dni:5A87, endpoint:01, cluster:0001, size:08, attrId:0021, encoding:20, command:0A, value:49, clusterInt:1, attrInt:33]
dev:972019-11-13 11:19:22.773 pm warnCommandResponse skipped clusterId:0006, descMap:[raw:catchall: 0000 0006 00 00 0040 00 5A87 00 00 0000 00 00 01FDFF0401010A0000, profileId:0000, clusterId:0006, clusterInt:6, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:5A87, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[01, FD, FF, 04, 01, 01, 0A, 00, 00]]
dev:972019-11-13 11:19:22.768 pm debugparseCommandResponse: [raw:catchall: 0000 0006 00 00 0040 00 5A87 00 00 0000 00 00 01FDFF0401010A0000, profileId:0000, clusterId:0006, clusterInt:6, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:5A87, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[01, FD, FF, 04, 01, 01, 0A, 00, 00]]
dev:392019-11-13 11:19:21.228 pm infoHome Thermostat thermostatOperatingState is idle
dev:1742019-11-13 11:19:21.050 pm infoLiving Room Home is idle
dev:1742019-11-13 11:19:20.424 pm infoLiving Room Home is playing
dev:972019-11-13 11:19:20.055 pm infoFront Door Lock was locked by digital command
dev:972019-11-13 11:19:20.046 pm debugparseCommandResponse: [raw:catchall: 0104 0101 01 01 0040 00 5A87 01 00 0000 20 01 0101FFFF00E54F5F2500, profileId:0104, clusterId:0101, clusterInt:257, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:5A87, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:20, direction:01, data:[01, 01, FF, FF, 00, E5, 4F, 5F, 25, 00]]
dev:392019-11-13 11:19:19.137 pm infoHome Thermostat heatingSetpoint is 71°F
dev:392019-11-13 11:19:19.134 pm infoHome Thermostat heatingSetpoint is 71°F
dev:352019-11-13 11:19:19.077 pm infoBedroom Overhead Light was turned off [digital]
dev:972019-11-13 11:19:19.053 pm debugparseCommandResponse: [raw:catchall: 0104 0101 01 01 0040 00 5A87 01 00 0000 00 01 00, profileId:0104, clusterId:0101, clusterInt:257, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:5A87, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:01, data:[00]]
dev:972019-11-13 11:19:19.036 pm debugparseCommandResponse: [raw:catchall: 0104 0101 01 01 0040 00 5A87 01 00 0000 00 01 00, profileId:0104, clusterId:0101, clusterInt:257, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:5A87, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:01, data:[00]]
dev:1612019-11-13 11:19:18.469 pm infoOffice Mini media source is Hubitat
dev:1622019-11-13 11:19:18.463 pm infoMaster Bedroom Mini media source is Hubitat
dev:1742019-11-13 11:19:18.448 pm infoLiving Room Home media source is Hubitat
app:2982019-11-13 11:19:16.984 pm infoAction: END-IF
app:2982019-11-13 11:19:16.977 pm infoAction: Thermostats: Home Thermostat:
--> Heat: 73
--> Cool: 76 (skipped)
app:2982019-11-13 11:19:16.943 pm infoAction: ELSE (skipped)
app:2982019-11-13 11:19:16.942 pm infoAction: Thermostats: Home Thermostat:
--> Heat: 64
--> Cool: 82 (skipped)
app:2982019-11-13 11:19:16.939 pm infoAction: ELSE-IF (Is Gone?(off) is on(F) [FALSE]) THEN (skipping)
dev:392019-11-13 11:19:16.823 pm debugsetCoolingSetpoint(73.0) was called
dev:392019-11-13 11:19:16.538 pm debugsetHeatingSetpoint(64.0) was called
app:3042019-11-13 11:19:16.432 pm infoHSM Alert: armedHome
app:2982019-11-13 11:19:16.414 pm infoAction: Thermostats: Home Thermostat:
--> Heat: 64
--> Cool: 73
app:2982019-11-13 11:19:16.390 pm infoAction: IF (Is Goodnight?(on) is on(T) [TRUE]) THEN
dev:342019-11-13 11:19:16.334 pm infoLiving Room Overhead Light was turned off [digital]
app:32019-11-13 11:19:16.188 pm infoArmed Home
app:2982019-11-13 11:19:16.186 pm infoUpdate Thermostat Setpoints: Actions run by Goodnight (triggered)
dev:2252019-11-13 11:19:16.137 pm infoOffice fan and light light was turned off
dev:3552019-11-13 11:19:15.572 pm infoIs Goodnight? was turned on
--- Live Log Started, waiting for events ---
It looks like the correct condition is executed, but the wrong temperature is set. This is with the delay removed. If I have the delay, the correct temperature is set.
I am not sure where 71F is coming from since I don't set that temperature.
Here is the log from when it set the temperature correctly
dev:2252019-11-13 11:32:44.497 pm infoOffice fan and light light was turned on
dev:392019-11-13 11:30:57.477 pm infoHome Thermostat thermostatSetpoint is 71°F
dev:392019-11-13 11:30:54.386 pm infoHome Thermostat thermostatOperatingState is idle
dev:392019-11-13 11:30:52.423 pm infoHome Thermostat coolingSetpoint is 73°F
dev:392019-11-13 11:30:50.791 pm infoHome Thermostat thermostatOperatingState is idle
dev:392019-11-13 11:30:48.181 pm infoHome Thermostat heatingSetpoint is 71°F
dev:3212019-11-13 11:30:48.143 pm infoMark Silva has arrived
app:2982019-11-13 11:30:45.941 pm infoAction: END-IF
app:2982019-11-13 11:30:45.939 pm infoAction: Thermostats: Home Thermostat:
--> Heat: 73
app:2982019-11-13 11:30:45.935 pm infoAction: ELSE (skipped)
app:2982019-11-13 11:30:45.934 pm infoAction: Thermostats: Home Thermostat:
--> Heat: 64
app:2982019-11-13 11:30:45.929 pm infoAction: ELSE-IF (Is Gone?(off) is on(F) [FALSE]) THEN (skipping)
dev:392019-11-13 11:30:45.896 pm debugsetCoolingSetpoint(73.0) was called
dev:392019-11-13 11:30:45.876 pm debugsetHeatingSetpoint(64.0) was called
app:2982019-11-13 11:30:45.867 pm infoAction: Thermostats: Home Thermostat:
--> Heat: 64
--> Cool: 73
app:2982019-11-13 11:30:45.863 pm infoAction: IF (Is Goodnight?(on) is on(T) [TRUE]) THEN
app:2982019-11-13 11:30:45.822 pm infoUpdate Thermostat Setpoints: Actions run by Goodnight (triggered)
dev:972019-11-13 11:30:39.195 pm warnCommandResponse skipped clusterId:0006, descMap:[raw:catchall: 0000 0006 00 00 0040 00 5A87 00 00 0000 00 00 02FDFF040101190000, profileId:0000, clusterId:0006, clusterInt:6, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:5A87, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[02, FD, FF, 04, 01, 01, 19, 00, 00]]
dev:972019-11-13 11:30:39.186 pm debugparseCommandResponse: [raw:catchall: 0000 0006 00 00 0040 00 5A87 00 00 0000 00 00 02FDFF040101190000, profileId:0000, clusterId:0006, clusterInt:6, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:5A87, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[02, FD, FF, 04, 01, 01, 19, 00, 00]]
dev:972019-11-13 11:30:37.814 pm infoFront Door Lock battery is 73%
dev:972019-11-13 11:30:37.812 pm debugparseAttributeResponse: [raw:5A870100010821002049, dni:5A87, endpoint:01, cluster:0001, size:08, attrId:0021, encoding:20, command:0A, value:49, clusterInt:1, attrInt:33]
dev:972019-11-13 11:30:37.295 pm warnCommandResponse skipped clusterId:0006, descMap:[raw:catchall: 0000 0006 00 00 0040 00 5A87 00 00 0000 00 00 01FDFF0401010A0000, profileId:0000, clusterId:0006, clusterInt:6, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:5A87, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[01, FD, FF, 04, 01, 01, 0A, 00, 00]]
dev:972019-11-13 11:30:37.288 pm debugparseCommandResponse: [raw:catchall: 0000 0006 00 00 0040 00 5A87 00 00 0000 00 00 01FDFF0401010A0000, profileId:0000, clusterId:0006, clusterInt:6, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:5A87, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[01, FD, FF, 04, 01, 01, 0A, 00, 00]]
dev:972019-11-13 11:30:34.465 pm infoFront Door Lock was locked by digital command
dev:972019-11-13 11:30:34.462 pm debugparseCommandResponse: [raw:catchall: 0104 0101 01 01 0040 00 5A87 01 00 0000 20 01 0101FFFF0087525F2500, profileId:0104, clusterId:0101, clusterInt:257, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:5A87, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:20, direction:01, data:[01, 01, FF, FF, 00, 87, 52, 5F, 25, 00]]
dev:972019-11-13 11:30:33.449 pm debugparseCommandResponse: [raw:catchall: 0104 0101 01 01 0040 00 5A87 01 00 0000 00 01 00, profileId:0104, clusterId:0101, clusterInt:257, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:5A87, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:01, data:[00]]
dev:972019-11-13 11:30:33.439 pm debugparseCommandResponse: [raw:catchall: 0104 0101 01 01 0040 00 5A87 01 00 0000 00 01 00, profileId:0104, clusterId:0101, clusterInt:257, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:5A87, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:01, data:[00]]
app:3042019-11-13 11:30:30.938 pm infoHSM Alert: armedHome
app:32019-11-13 11:30:30.727 pm infoArmed Home
dev:2252019-11-13 11:30:30.720 pm infoOffice fan and light light was turned off
dev:3552019-11-13 11:30:30.369 pm infoIs Goodnight? was turned on
Initially, 71F was the setpoint for the else clause, so I thought it was hitting that condition. Now that I am setting a different value, it is obvious that this number is coming from somewhere else.
The thermostat is a Filtrete branded Radio Thermostat that can take multiple radio modules. Right now there is only the Z-Wave module installed and the device type is set to Generic Z-Wave Thermostat.
Let me know if there is something else to try, or more logs that would help. Since I have a workaround, I don't consider this a high priority or anything.
