Hello,
i need your help. I think that is possible but not now how
i have pressure contact on water line. When contact is open need to turn on pump switch.
now i would like to have two safe condition.
more that 5 switch turn on in one minute. ( must set an alarm / turn on one light/switch)
That pump switch is turned on more that 30 min (must turn off) .
thanks for any help.
There are several ways to do this. Here is one using Rule Machine.
For #1:
You will need to decide how it gets reset back to 0 - should that happen after the light or alarm turns on?
For #2:
hello,
how i make this tipe of conditions: (Variabile Counter(0) > 5 (F)
this is my first rule. I need la little help
thanks
i would like to have one rule for both action.
First, create the “Counter” variable:
Then select the actions to run:
system
Closed
5
