Please consider adding "Adjust lights on time period change" to the Set up Lighting Periods page. I, and I would guess others, assumed that setting up time periods in a contiguous block with different light settings would automatically transition as the periods changed.
I know that. And I didn't look for it because I expected that would be the default. If the adjust on time periods change option was visible on the same page where time periods are set up its required use might be apparent.
