So I want to turn my Air Exchanger on for 20min then off or 40min, continuously repeat.
Before I start to try and figure this out has anyone done something similar?
Using a thermostat or switch or outlet? If it is a thermostat, do you want to factor heating and cooling run time into it? If not,
It is a simple rule
Thanks thats too simple, LOL
I was playing with periodic schedule:
Pause
Name this Rule*
Select Trigger Events
Every 20 minutes
Select Actions to Run
Off: Air Exchanger On: Air Exchanger --> delayed: 0:19:00
Logging
Click to set
Run Actions
Update Rule
Create Local Variables
The only other thing that I do is never start on the hour, I usually start things at non even times, like 23 minutes, so things don't line up.
I agree and definitely do not trigger at noon or midnight.
Well this worked until midnight then stopped running.... do i have to set something else to run every day?
I had it set to start at 5:01pm every hour so I think that means it will run every hour from 501 to midnight. So I changed it to start at 1201am so hopefully that means it will run all 24 hours of the day
