I have two like tilt sensors both using the generic Zwave contact driver.
Only one of them shows the contact in the status, tried using another toggling the driver but still no luck.
What do you mean? There is no toggle command in the Generic Z-wave contact sensor driver.
I tried a different driver and them back to the generic driver. This worked on the other tilt sensor
Current States
- battery : 100
- tamper : detected
"It don't have contacts"
Did you hit configure?
Yes
When I hit configure should something happen?
And this is the same model tilt sensor?
Thank you for your help!!
