Tile Master - Vertical Alignment Varies?
I have simply tolerated this, and I do not see any way to fix it. This is a completely "standard" use of the TileMaster app, no special formatting was attempted, default and global values are used.
So why can't it get the spacing right, and while we are here, why do I have both the "attribute type" at the top, and the virtual device type at the bottom of the tile? Why can't those disappear?
Screenshot 2023-12-03 115810
You can get rid of the top 'tm-tile01' text by going into the options for the dashboard and ticking this.
Do both have the same number of lines in TM?
Yes they do have the same number of lines, and I check with care to keep both as "generic" as possible, using only default values.
But, the visual uglies were cured by @bobbles suggestion. Works like a champ, much more gooder.
