@monsterdykaren, I worked with @mailtomatte for a while trying to get live measurements to work. We were not able to get it to work, because real-time reporting requires a Tibber Pulse or Watty device, which neither of us have. Do you have either of those?
Sadly not.
Sorry to poke an old thread, but I have a Tibber Pulse device
Cool! Try the code in my post here: Tibber integration? - #18 by tomw
It's a very slightly modified version of the code that Tibber shared for use with SmartThings.
Also FYI: @Carl
- currency : NOK: Øre/kWh
- energy : 2.597
- price : 62
- priceMaxDay : 65
- priceMaxDayLabel : Max price @ 09
- priceMinDay : 52
- priceMinDayLabel : Min price @ 06
- priceNextHour : 62
- priceNextHourLabel : @ 19 - 20
- pricePlus2Hour : 62
- pricePlus2HourLabel : @ 20 - 21
Trying to refresh makes the energy "null". The values are otherwise correct.
Thank you for the debug prints.
It looks like the duration of this energy measurement is 1 hour (20:00-21:00). This would mean that your consumption was .395 kWh in that hour. Does the app tell you the time period for the averaged power measurement? The daily total that you mentioned seems too low if the average usage throughout the day was 372 W. But if that was the average usage for the past hour, perhaps it makes sense.
That is odd. Which step causes it to again show a value in energy, if refresh marks it to null? Is there anything mentioned in the debug log in Hubitat?
You can search for log.debug in the code and comment the uninteresting lines out (add // to beginning of line) or delete them completely.
Hi
Could someone please help port this updated Smartthings version of the tibber DH?
Looks like, outside of some capabilities that don’t map, that the code should pretty much work as is. Try this code as a device driver:
Ported Code
* Copyright 2017 Tibber
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
* Tibber price
* Author: tibberdev,cscheiene
metadata {
definition (name: "Tibber Price", namespace: "cscheiene", author: "tibberdev, cscheiene", mnmn: "SmartThingsCommunity", vid: "560e33c3-94b5-3b05-970c-de5af9ae5ae9", ocfDeviceType: "x.com.st.d.energymeter") {
capability "Sensor"
capability "Refresh"
/* capability "islandtravel33177.tibberPriceNextHour"
capability "islandtravel33177.tibberPrice"
capability "islandtravel33177.tibberPriceMaxDayLabel"
capability "islandtravel33177.tibberPriceMaxDay"
capability "islandtravel33177.tibberPriceMinDay"
capability "islandtravel33177.tibberPriceMinLabel"
capability "islandtravel33177.tibberPricePlusTwoHour"
capability "islandtravel33177.tibberPriceLevel"
capability "islandtravel33177.tibberConsumptionPrevHour"
capability "islandtravel33177.tibberPriceNextHourDisplay"
capability "islandtravel33177.tibberPricePlusTwoHourDisplay"
capability "islandtravel33177.tibberPriceMinDayDisplay"
capability "islandtravel33177.tibberPriceMaxDayDisplay"
capability "islandtravel33177.tibberAddress" */
capability "Energy Meter" //workaround for Actions tiles etc
attribute "currency", "string"
preferences {
input (
type: "password",
title: "API Key",
description: "Enter the Tibber API key",
required: true,
displayDuringSetup: true
input (
type: "paragraph",
title: "API Key can be found here:",
description: "https://developer.tibber.com/settings/accesstoken"
input (
type: "number",
title: "Home",
description: "Enter the home you want to display, default is 0",
required: true,
displayDuringSetup: true,
input (
type: "paragraph",
title: "NORMAL",
description: "The price is greater than 90 % and smaller than 115 % compared to average price."
input (
type: "paragraph",
title: "CHEAP",
description: "The price is greater than 60 % and smaller or equal to 90 % compared to average price."
input (
type: "paragraph",
title: "VERY CHEAP",
description: "The price is smaller or equal to 60 % compared to average price."
input (
type: "paragraph",
title: "EXPENSIVE",
description: "The price is greater or equal to 115 % and smaller than 140 % compared to average price."
input (
name: "VERY EXPENSIVE",
type: "paragraph",
title: "VERY EXPENSIVE",
description: "The price is greater or equal to 140 % compared to average price."
input (
type: "paragraph",
title: "Version number",
description: "140421"
def homeNumber() {
if(settings.home == null){
return 0
} else {
return settings.home}
def initialize() {
state.price = 100;
log.debug("init")
getPrice()
schedule("0 1,5,10,15,20,25,30 * * * ?", getPrice)
def installed() {
log.debug "Installed"
initialize()
def ping() {
refresh()
def updated() {
log.debug "Updated"
initialize()
def refresh() {
initialize()
def getPrice() {
log.debug("getPrice")
if(tibber_apikey == null){
log.error("API key is not set. Please set it in the settings.")
} else {
def params = [
uri: "https://api.tibber.com/v1-beta/gql",
headers: ["Content-Type": "application/json;charset=UTF-8" , "Authorization": "Bearer $tibber_apikey"],
body: graphQLApiQuery()
try {
httpPostJson(params) { resp ->
if(resp.status == 200){
def today = resp.data.data.viewer.homes[homeNumber()].currentSubscription.priceInfo.today
def tomorrow = resp.data.data.viewer.homes[homeNumber()].currentSubscription.priceInfo.tomorrow
def price = Math.round(resp.data.data.viewer.homes[homeNumber()].currentSubscription.priceInfo.current.total * 100)
def priceMaxDay = Math.round(MaxValue(today) *100)
def priceMaxDayLabel = "${MaxValueTimestamp(today)}:00"
def priceMinDay = Math.round(MinValue(today) *100)
def priceMinDayLabel = "${MinValueTimestamp(today)}:00"
def priceList = today
tomorrow.each{
priceList << it
def priceNextHours = PriceNextHours(priceList)
def priceNextHour = Math.round(priceNextHours[0] *100)
def priceNextHourLabel = "@ ${priceNextHours[2]}"
def pricePlusTwoHour = Math.round(priceNextHours[1] *100)
def pricePlusTwoHourLabel = "@ ${priceNextHours[3]}"
def currency = resp.data.data.viewer.homes[homeNumber()].currentSubscription.priceInfo.current.currency
def level = resp.data.data.viewer.homes[homeNumber()].currentSubscription.priceInfo.current.level
def consumptionPrevHour = resp.data.data.viewer.homes[homeNumber()].consumption.nodes[0].consumption
def address = resp.data.data.viewer.homes[homeNumber()].address.address1
currency = "${currency}: ${currencyToMinor(currency)}/kWh"
state.currency = currency
state.level = level
state.price = price
state.priceNextHour = priceNextHour
state.priceNextHourLabel = priceNextHourLabel
state.pricePlusTwoHour = pricePlusTwoHour
state.pricePlusTwoHourLabel = pricePlusTwoHourLabel
state.priceMaxDay = priceMaxDay
state.priceMaxDayLabel = priceMaxDayLabel
state.priceMinDay = priceMinDay
state.priceMinDayLabel = priceMinDayLabel
sendEvent(name: "consumptionPrevHour", value: consumptionPrevHour, unit: "kWh")
sendEvent(name: "address", value: address)
sendEvent(name: "energy", value: price, unit: currency)
sendEvent(name: "price", value: state.price, unit: currency)
sendEvent(name: "priceNextHour", value: state.priceNextHour, unit: currency)
sendEvent(name: "pricePlusTwoHour", value: state.pricePlusTwoHour, unit: currency)
sendEvent(name: "priceMaxDay", value: state.priceMaxDay, unit: currency)
sendEvent(name: "priceMinDay", value: state.priceMinDay, unit: currency)
sendEvent(name: "priceMinDayDisplay", value: "$priceMinDay $currency @ $priceMinDayLabel")
sendEvent(name: "priceMaxDayDisplay", value: "$priceMaxDay $currency @ $priceMaxDayLabel")
sendEvent(name: "priceNextHourDisplay", value: "$priceNextHour $currency $priceNextHourLabel")
sendEvent(name: "pricePlusTwoHourDisplay", value: "$pricePlusTwoHour $currency $pricePlusTwoHourLabel")
sendEvent(name: "priceMaxDayLabel", value: state.priceMaxDayLabel)
sendEvent(name: "priceMinDayLabel", value: state.priceMinDayLabel)
sendEvent(name: "currency", value: state.currency)
sendEvent(name: "level", value: state.level)
log.debug "$address"
} catch (e) {
log.debug "something went wrong: $e"
log.debug "parse description: ${description}"
def eventMap = [
createEvent(name: "energy", value: state.price, unit: state.currency)
,createEvent(name: "level", value: state.level)
,createEvent(name: "price", value: state.price, unit: state.currency)
,createEvent(name: "priceNextHour", value: state.priceNextHour, unit: state.currency)
,createEvent(name: "pricePlusTwoHour", value: state.pricePlusTwoHour, unit: state.currency)
,createEvent(name: "priceMaxDay", value: state.priceMaxDay, unit: state.currency)
,createEvent(name: "priceMinDay", value: state.priceMinDay, unit: state.currency)
,createEvent(name: "priceNextHourLabel", value: state.priceNextHourLabel)
,createEvent(name: "pricePlus2HourLabel", value: state.pricePlus2HourLabel)
,createEvent(name: "priceMaxDayLabel", value: state.priceMaxDayLabel)
,createEvent(name: "priceMinDayLabel", value: state.priceMinDayLabel)
,createEvent(name: "currencyLabel", value: state.currency, unit: state.currency)
log.debug "Parse returned ${description}"
return eventMap
def currencyToMinor(String currency){
def currencyUnit = "";
switch(currency){
case "NOK":currencyUnit = "Øre";break;
case "SEK":currencyUnit = "Øre";break;
case "USD":currencyUnit = "Penny";break;
default: currencyUnit = "";break;
return currencyUnit;
def graphQLApiQuery(){
return '{"query": "{viewer {homes {address{address1} consumption(resolution: HOURLY, last: 1) {nodes {consumption consumptionUnit}} currentSubscription {priceInfo { current {total currency level} today {total startsAt} tomorrow{ total startsAt }}}}}}", "variables": null, "operationName": null}';
def MaxValueTimestamp(List values){
def max = 0
def maxTimestamp = ""
values.each{
def timestamp = it.startsAt
def total = it.total
if(total>max){
max = it.total
maxTimestamp = timestamp
return maxTimestamp.substring(11,13)
def MaxValue(List values){
def max = 0
values.each{
if(total>max){
max = it.total
return max
def MinValueTimestamp(List values){
def min = 1000
def minTimestamp = ""
values.each{
if(it.total<min){
min = it.total
minTimestamp = timestamp
return minTimestamp.substring(11,13)
def MinValue(List values){
def min = 1000
values.each{
if(it.total<min){
min = it.total
return min
def PriceNextHours(List values){
def priceNowTimestamp = 0
def priceNextHour = -1;
def priceNextNextHour = -1;
def i=0
values.each{
Calendar cal=Calendar.getInstance();
def hourNowUtc = cal.get(Calendar.HOUR_OF_DAY) + 1
def dayNowUtc = cal.get(Calendar.DAY_OF_MONTH)
def startsAt = it.startsAt
int hourNow = startsAt.substring(11,13) as int
int dayNow = startsAt.substring(8,10) as int
int hourOffset = startsAt.substring(20,22) as int
def timeZoneOperator = startsAt.substring(19,20)
if(timeZoneOperator=="+"){
hourNowUtc = hourNowUtc + hourOffset
if(timeZoneOperator=="-"){
hourNowUtc = hourNowUtc - hourOffset
if(hourNowUtc<0){
hourNowUtc = hourNowUtc+24 //wrap
dayNowUtc = dayNowUtc-1
if(hourNowUtc>23){
hourNowUtc = hourNowUtc-24 //wrap
dayNowUtc = dayNowUtc+1
if(hourNow == hourNowUtc && dayNow == dayNowUtc ){
priceNextHour = it.total
priceNextNextHour = values[i+1].total
priceNowTimestamp = hourNowUtc
i++
def priceNextTimestamp = 0
if(priceNowTimestamp<23)
priceNextTimestamp = priceNowTimestamp + 1
return [priceNextHour, priceNextNextHour, fromToTimestamp(priceNowTimestamp), fromToTimestamp(priceNextTimestamp)]
def fromToTimestamp(def timestamp){
def from = timestamp
def to = timestamp + 1
if(to>23){
to = 0
return "${formatTimestamp(from)} - ${formatTimestamp(to)} "
def formatTimestamp(def timestamp){
if(timestamp < 9)
return "0${timestamp}"
return timestamp
Was wondering if the non-standard capabilities had external references. Looks like they do, but a quick search through the public repositories didn't turn up anything I can use to resolve.
