Look at this rule:
In the second IF statement there are three False indicators (F)(F)(F) in a row. Why is that?
Look at this rule:
Previously added conditions that no longer exist or from editing and not leaving the RM using the done button (e.g. back button in browser, just closing browser mid edit). If you edit it, you should be able to delete the extra conditions. You can also just delete and re-create the line.
I recreated the rule from scratch and that fixed it. Thanks!
So is this similar to a device ghost? If left alone is it possible it might wreak havoc on the mesh?
I don't believe so, but it would cause the rule to misbehave.
