THIRDREALITY Zigbee outlet stops reporting wattage
It would be particularly helpful if you shared your rule and a description of what you want it to do so someone can advise if there is a different approach that might work better for your goal.
I have removed your duplicate post below mine. Everyone can see all replies, so there is no reason to post the same response multiple times. Please also consolidate multiple successive replies, if needed, into one post as has been asked of you previously, and use the quote feature if needed to make replies clear. Continued violation of this community guideline may result in flags, and multiple flags may result inaccount suspension. Thanks for your cooperation!
