ThirdReality Vibration Sensor and Tile status
Hi,
I have a Zigbee, Third Reality Vibration Sensor, that is working with Hubitat (the device type is Third Reality Vibration Sensor, so i suspect its using the correct driver). It seem be exporting "acceleration" and "battery" states, from the device info page.
However in EZ Dashboard, this device is classified under "contact sensors", and adding a tile for this device results in status no being reported, and the tile complains with this error:
Invalid Attributes: contact
How do I add a tile for vibration sensor in EZ Dashboard?
I am using a C-7 running 2.3.9.200
Thanks in advance!
R
PS:
  • I had bunch of screenshots, that I wanted to upload showing more details; but seems I cannot post images (yes, this is my first post!)
  • @bobbyD -- do i need to update any settings on my account to allow me post images+urls?
Sort of, you just need to join the "owners" group:
https://community.hubitat.com/g
For the actual problem:
It's likely Easy Dashboard does not support plain vibration sensors (I don't have any to test; all mine also have other capabilities, like motion or contact, which the dashboard prioritizes, but I don't see anywhere to select this when you change the tile type regardless, hence this conclusion). You will likely need the more advanced/customizable Hubitat Dasbhoard if you want this attribute visible on a dashboard.
Just did. thanks!
Thanks. Yes, I tried using the "Hubitat Dashboard" (that unfortunately seems to be marked as "legacy", fwiw) and could create a tile for this device, using "acceleration" template, and that seems to be reporting the status correctly.
I have a bunch of vibration (and other non standard sensors to EZ dashboard). I think I will switch to the non-EZ version of the dashboard and use that for now.
Thanks again for the quick help, appreciate it!
R
