I’ve successfully set up the Third Reality Soil Moisture Sensors with Hubitat hub (C-7) and can see RH%, battery, and temperature. However, they don’t seem to update regularly after the initial connection.
I’ve already moved the hub closer to the sensors and added a few Third Reality plugs to strengthen the Zigbee mesh, but updates are still infrequent.
Any suggestions to ensure the sensors report to Hubitat at least once daily?
I would try this driver, it has settings for more frequent reports. It works with many Zigbee temp/humidity sensors and a soil moisture sensor is in the list (as soil moisture is really a humidity sensor).
