Thermostats and Dashboards in 2.0 iOS app
New App doesn't display thermostats correctly. Why replace the app - the old app worked just fine - the new app is a mess - especially the dashboards.
Dashboards are the same in both versions of the app. It sounds like you might be dealing with other problems, and someone might be able to help if you explain more, perhaps including screenshots or more descriptions of what you're seeing where.
@user5411 Typically it's a driver issue. I assume you are using a 3rd party driver. You need to use either a built in or get the author to fix it.
