Thermostat Temp Swing
Just swapped my emerson sensi for the gocontrol zwave thermostat.
I'd like to set up a 10 or 15 degree heat cycle in my garage. Is this done setting temp to desired level and then select a 10 degree offset, which would allow the temp to drop 10 degrees below the currently set level? (Not fully understanding what an offset is maybe)
Or do I have to set up a rule in RM that turns heat mode to off at certain hi temp and then back on at a certain low temp?
Can you post the exact temperature range you want in your garage? Also, what temperature sensors are you using?
I have no sensors. Prior I was using wink and using the thermostats read out to change mode from heat to off at 65 degrees and the from off to heat at 50 degrees.
Is HE able to use the temp of the garage itself from a dedicated thermostat (has dedicated hanging furnace) as triggers for changing modes via temp readout?
