I've been using Thermostat Scheduler app for quite a while but since it's pretty warm where I live so it rarely has to switch from cooling to heating. Today I discovered that the Thermostat Scheduler won't automatically switch modes. It's been working fine for adjusting the cooling based on time periods and following rules enabling/disabling eco mode.
I have both heating and cooling setpoints. The screenshot example shown shows the current temp of 71.6 when the heat setpoint is 72, but the mode is still on Cool (there was a lot wider difference earlier). If I manually switch the thermostat mode to Heat, it works fine.
My thermostat is a Honeywell T6 Pro Z-Wave Thermostat and I'm on a C7 Hub running 2.3.0.124.
