Hello all - Just transitionning from Smartthings to Hubitat -
I am testing each devices one by one - Stelpro KI (Zwave) is my next move. I managed to upload the Smartthing conversion that was posted in the forum. I can now see Setpoint and current temperature. My next move was to try to control the thermostat. So I decided to add the Thermostat scheduler as per the screenshot below. I am having a null pointer error on mainpage. This seems similar to some other post for the Zigbee version, but not sure where to start... if anyone has an idea... I'll appreciate.
For some reason, I believe it is related to the fact that when selecting the thermostat - (there is only one Sophie-Th) it does not fill the field with an *.... therefore the code cannot create the child with a nul ( space ) name....
This is caused by the driver. Your thermostat device has no thermostatMode attribute, as shown in your Current States screenshot above. Have you tried setting the thermostat mode with the tile on the device page? Your Current States should show a thermostatMode like this:
Thanks. 1 bug to 1
I'll try to make sense of what you just gave me.
My Groovy skill's are far from being optimal, not to mention my Zwave knowledge.
Time to learn
Cheers
J.
