Currently running: 2.3.3.123
For some reason, the night timepoint does not set the temperature. As you can see from the logs, the other timepoints work fine. Any ideas?
That's odd. I will investigate...
Even odder, when I test it just like yours, it works as expected. I'll put some more effort into it tomorrow, replicating yours exactly...
Figured it out, I think.
It looks like the scheduler sets the coolingSetpoint, THEN sets the mode to cool (based on timing in the logs).
This driver ignores cooling setpoints if the thermostat is not already in cool (the thermostat happened to be off at the 9pm timepoint). However, would that prevent the scheduler from logging? I will see tomorrow, I guess.
I changed the driver since it's a user driver. (though it does make sense to me that the mode should be set before the temperature is set)
Yes, I figured out the same thing. Fix for this coming... It obviously should set the mode first. It uses the mode to determine whether or not to set cooling / heating.
Fix for this released: Release 2.3.3 Available - #6 by bravenel
