I have a couple GoControl TBZ48 thermostats and really like them. The 2nd floor stat is located in the hallway and is problematic with closed bedroom doors and forced air HVAC. I have AQORA temp sensors in bedrooms and Im wondering if someone can tell me if and how I can setup the thermostat to run off of a temp sensor in the bedroom instead of at the thermostat itself in the hallway. ANY HELP WOULD BE GREATLY APPRECIATED!!
The simplest way would be to use the built-in thermostat controller app.
Thank you. I am using the Thermostat Controller app. My question is about how to implement the use of temperature sensors so the thermostat is reading from those instead of at its own location......
Not sure if you've seen it, but the app has documentation which includes setup and use of an external temperature.
https://docs.hubitat.com/index.php?title=Thermostat_Controller
Note that the local thermostat reading on the thermostat will always be it's local/built-in temperature, not the remote one. The controller app works by adjusting the the thermostat setpoint based on the external temperature reading.
