Hi,
I just set up Thermostat Controller with a portable Midea A/C using a SwitchBot temperature sensor. Maybe it'll work fine, but I think I keep noticing that the "Controlled Thermostat" cool temp goes up to 70 whenever the controller sends an update to the A/C, and on the A/C itself I see a temp set of 70. Unfortunately, as you might expect, the temp sensor on the A/C is like 5 degrees cooler than the sensor on the other side of the room, so if the A/C is actually set to 70, then it turns off. How do I make sure that the app works properly?
(First night using this, so maybe it will be fine, but I'm worried either it will keep setting to 70 or it'll actually cool to 64.5 based on external temp
Screenshot of the app:
