Hi,
I've tried and tried, and have ended up getting more and more frustrated. The "help" section/instructions with screenshots gets one only so far.
I have set up about a dozen of these controllers, sometimes after deleting and starting from scratch, following instructions to the letter. Sometimes I have had some limited success. Then it goes wrong. Other times it's just baffling from the outset.
Is there a better set of instructions anywhere?
I'm very close to giving up on the whole thing, but I've invested in these things, and made an undertaking to a number of people to get them working. We need something like this, and I'll probably start a thread on the "big picture" to see if anyone has some suggestions.
Behaviours I'm seeing:
Set up thermostat controller, turn it to controlled: in the device it shows free. Have to turn it to controlled in there too.
Turn heat up using controller: controlled thermostat goes up, mode is heat.
Turn heat down using controller: controlled thermostat stays same, but mode goes to off.
Set controlling thermostat to 23ºC: controlled thermostat changes to 0.0ºC. Can't figure out how to change it to something else using controlling thermostat.
Honestly, whilst I fully appreciate that Hubitat is not aimed at the standard user, and is necessarily more techie and complicated, I am frustrated at the level of voodoo required to get this working.
I realise that I'm not asking specific questions here, and that's part of the reason I have not reached out so far (after about 6 months of wrestling), but I barely know what to ask. Beyond "what the hell?" I am left scratching my head at which variables might conceivably being throwing me off track here!
For reference, I am trying to control Moes BRT-100 TRVs, which are running using Tuya Wall Thermostat driver. These essentially work, or at least they could do!
I'll create a separate topic with my ultimate goal. I thought I would have got there by now, but this is, frankly, the main stumbling block. Anyone got a magic wand?
Thank you!
