Hi all,
I had a quick questions/clarification on two of the thermostat controller setting. I am trying to understand the difference between "Hysteresis" and "Control Offset". I think I understand it but not totally sure. So if my thermostat is set to 70 degrees and the temperature drops to 65.5 then the Hysteresis setting will cause the furnace to kick on. From there the Control offset will refer to the heat setpoint(70 degrees) and tell the furnace to turn off when it reaches that degree offset. So if that offset was set to 1 then the furnace would turn off at 71.
Is my understanding of these setting correct?
