Thermostat Controller how to use
A few weeks ago I bought two ZWAVE thermostats to control MINISPLITS units. MCOHome Ir2900 (driver MCO Home IR Thermostat)
and Remotec ZXT600. I was able to configure both, however I have some problems controlling AIRSWING. MCOHome IR2900 controls a Panasonic. I can control it from a Dashboard or turn it on directly from the MCO thermostat. That way it works ok. However, when I turn it on via voice command through Alexa, the thermostat turns on and then activates the AIRSWING function which I have no way to turn off or control from HE. The only way to turn it off is from the original remote control of the air conditioner. I would also like to better understand the Thermostat Controller application since in that application I can delete AIR MODES such as HEAT that I do not need but it cannot be done on the thermostat. On there Thermostat Controller app I selected the option CONTROLLED instead of Free. I share some images. Thanks for the feedback
Hello any feedback? Thank you
I have a Midea minisplit and I want know if this thermostat can act as remote temperature sensing? Midea call it "Follow me" and got temp sensing from the ir remote.
