Does anyone know of a zwave thermal smoke detector replacement device similar to the picture below? The device detects heat past a certain threshold.
The only z-wave smoke detector Iβve seen is the ZSMOKE (or ZCOMBO, which also does CO) by First Alert.
Does that thermal detector output the standard beeping sound typical of "normal" smoke detectors? If so, consider a smoke detector detector (no, I didn't just have a stroke). It is the Ecolink FF-ZWAVE5-ECO. It brings in any type detector via Zwave.
This one sensor can listen for the C0 and smoke signals, and give different messages about either. It allows you to use hardwired detectors like my house has. There aren't Zwave hardwired detectors for some odd reason. You don't have to change this listening device if you change detectors.
Anyhow, it is fairly inexpensive, and seems to work good. I burned toast the other day, the normal detectors went off, and the Ecolink picked up their sound and ran all my automations just fine.
+1 for the ecolink firefighter. They came out with a zigbee version recently too.
Iβm also curious re: whether the heat sensor in the device triggers the standardized smoke alarm pattern.
The pic in OP indicates itβs got a regular photoelectric sensor for smoke in addition to the heat sensor.
There's also the Ring Alarm Smoke & CO Listener.
Supported natively by HE.
