The “MY” button on a RF Somfy blind
C8 running near current firmware
Connected to a Bond Pro via the Bond Integration app.
A Somfy blind has 3 buttons on the remote, up, down and MY. The MY button stops the blind in a preset position. The blind uses uses the RMS42 Bond profile.
I realize the bond bridge communication is one-way, but I don’t seem to be able to mimic the MY button using Hubitat.
has anyone managed to make this work?
TYIA
This integration, as I understand it, was based on a Community developed integration by a user who is no longer on the Hubitat platform (Dominic). I've never had a need to transition off Dominic’s version, so I am still running it myself.
Dominic did introduce a feature where calling the Set command with a value of 50 would adjust the shade to the My position. I am not sure whether or not that made it into the built-in integration, but you could try it and see what happens
Thank you. I really appreciate it
Which app should I be looking at?
This is the GitHub repository, but it is also available in HPM, so I would start by looking there.
Cheers. :+1:t2:
